12/07/2025 at 16:46 #3512
Introduction: Why Viscosity Matters in Flow Measurement
In industrial applications, accurate flow measurement is vital for maintaining efficiency, ensuring quality, and optimizing costs. However, one major challenge arises when handling high-viscosity fluids—substances that are thick, sticky, and resistant to flow. From adhesives and syrups to heavy oils and polymers, these fluids require specialized instruments to achieve reliable results. This is where a high viscosity mass flow meter comes into play.
Many standard flow meters struggle with viscous substances, leading to inaccurate readings, clogs, or even system failure. In contrast, a high viscosity mass flow meter is specifically engineered to manage the complex behavior of dense fluids. In this article, we explore the importance of such devices, how they work, and why Accura Instrument (Shanghai) Co., Ltd. is at the forefront of providing advanced solutions for challenging applications.
Understanding High Viscosity Fluids
Viscosity refers to a fluid’s resistance to flow. The higher the viscosity, the thicker the fluid. Common high-viscosity materials include:
Molasses
Bitumen
Greases and lubricants
Resin and glue
Paints and coatings
These materials pose significant challenges for traditional flow meters, which often rely on fluid velocity or volume to calculate flow. The resistance caused by viscosity interferes with such measurements, rendering them unreliable.
A high viscosity mass flow meter, on the other hand, operates on the principle of mass rather than volume or velocity, ensuring precise and consistent readings regardless of fluid thickness.
What is a High Viscosity Mass Flow Meter?
A high viscosity mass flow meter is designed to measure the mass flow rate of fluids with high resistance to flow. It does this by relying on Coriolis or thermal principles rather than mechanical or volumetric methods.
Key Features:
Accuracy: Even with dense or unevenly flowing fluids.
Durability: Engineered to withstand abrasive and sticky substances.
Flexibility: Applicable across industries like chemical processing, food and beverage, oil and gas, and pharmaceuticals.
Accura Instrument (Shanghai) Co., Ltd. has developed a range of high viscosity mass flow meters tailored to meet these complex requirements. Their instruments are renowned for performance, longevity, and precision.
How Do High Viscosity Mass Flow Meters Work?
The Coriolis Effect
The most common type of high viscosity mass flow meter is the Coriolis mass flow meter. It operates by measuring the deflection caused when a fluid flows through vibrating tubes. This deflection, known as the Coriolis force, is directly proportional to the mass flow rate.
Even with viscous materials that resist movement, the Coriolis effect allows for accurate mass measurement. Since mass doesn’t change with temperature or pressure, it provides a more stable and reliable metric than volume or velocity.
Thermal Dispersion Technology
Another method employed is thermal dispersion, where the difference in temperature caused by a flowing fluid is used to determine mass flow. While this is less common for highly viscous fluids, advanced models from companies like Accura Instrument (Shanghai) Co., Ltd. incorporate hybrid techniques for broader application ranges.
Why Standard Flow Meters Fail with High-Viscosity Fluids
Issues with Mechanical Flow Meters
Mechanical meters such as gear or turbine types often become clogged or fail to turn properly when dealing with high-viscosity materials. Their moving parts are not suited to the slow or uneven flow of thick fluids.
Challenges with Electromagnetic Meters
Electromagnetic flow meters require the fluid to be conductive. Many high-viscosity fluids, especially oils or polymers, don’t meet this requirement, rendering such meters useless in those contexts.
Only a high viscosity mass flow meter can handle the demands of both non-conductive and extremely dense fluids with a high degree of accuracy and repeatability.
Applications of High Viscosity Mass Flow Meters
These instruments are invaluable across numerous industries, especially when quality control and process efficiency are non-negotiable.
Oil & Gas
Measuring crude oil, tar sands, or drilling fluids accurately is essential. A high viscosity mass flow meter ensures accurate measurements even in the most demanding environments.
Food & Beverage
Products like chocolate, molasses, and syrups require precise flow measurement for both consistency and compliance. High-viscosity meters help maintain recipe accuracy during automated processes.
Chemicals & Polymers
In chemical processing plants, dealing with glues, resins, and polymers is routine. Instruments from Accura Instrument (Shanghai) Co., Ltd. are designed to operate flawlessly even with sticky or reactive substances.
Pharmaceuticals & Cosmetics
From ointments to gels, many pharmaceutical and cosmetic products involve high-viscosity materials. A reliable high viscosity mass flow meter ensures formulation accuracy and regulatory compliance.
Why Choose Accura Instrument (Shanghai) Co., Ltd.?
Industry Expertise
With years of experience in flow measurement technology, Accura Instrument (Shanghai) Co., Ltd. understands the unique challenges posed by high-viscosity fluids. Their team of engineers works closely with clients to deliver customized solutions that exceed industry standards.
Innovation in Design
Accura’s high viscosity mass flow meters incorporate advanced Coriolis and hybrid technologies, ensuring exceptional accuracy across a wide viscosity range. Their meters feature:
Robust, clog-resistant designs
Real-time digital output
Integrated temperature and density sensors
Compatibility with hazardous environments
Global Reputation
The company has built a strong reputation for quality, reliability, and innovation. With installations across Asia, Europe, and the Americas, Accura Instrument is a trusted name in industrial flow measurement.
Choosing the Right High Viscosity Mass Flow Meter
When selecting a high viscosity mass flow meter, consider the following:
Fluid characteristics: Is it sticky, abrasive, or corrosive?
Flow rate range: What is the expected minimum and maximum flow?
Installation environment: Is it hazardous or temperature-sensitive?
Output requirements: Do you need digital, analog, or wireless monitoring?
Accura Instrument (Shanghai) Co., Ltd. offers expert consultations to help industries make the right choice. Their application-specific solutions are built to deliver maximum ROI over the long term.
Maintenance and Calibration
Though high viscosity mass flow meters are known for their reliability, routine maintenance and calibration ensure long-term performance. Accura Instrument provides:
On-site support
Remote diagnostics
Regular calibration services
Spare parts and technical assistance
These services ensure your flow meters continue to perform at peak efficiency, even under the most extreme operating conditions.
Final Thoughts
A high viscosity mass flow meter is not just a specialized instrument—it's a critical component in the industrial measurement landscape. Whether you're managing food production, refining petroleum, or manufacturing chemicals, the need for accurate flow measurement cannot be overstated.
Accura Instrument (Shanghai) Co., Ltd. delivers high-performance solutions designed to meet the specific demands of high-viscosity applications. Their commitment to innovation, quality, and customer satisfaction makes them a leader in the field.
If you’re struggling with inaccurate readings, equipment clogs, or inefficient systems due to viscous materials, it may be time to upgrade. Explore the range of high viscosity mass flow meters offered by Accura and bring precision back into your process.
Contact Accura Instrument (Shanghai) Co., Ltd. today to learn more about how their high viscosity mass flow meter solutions can transform your operations.
https://www.accurainstrument.com/Mass-Flowmeter
Accura Instrument (Shanghai) Co., Ltd. -
