07/07/2025 at 14:30 #3433
In the marine leisure and water transport industry, air conditioning has long been an important device to ensure the comfort of ships. Compared with traditional AC air conditioning systems, DC marine air conditioners are increasingly favored by users of small and medium-sized ships and yachts due to their advantages such as low energy consumption, fast startup, and strong compatibility. However, there are many types of DC marine air conditioners on the market with different performances. How to choose a device that is both in line with the ship's power supply system and can effectively cool has become a problem that many ship owners and shipyards must face before purchasing.
This article will focus on the core issue of "What parameters should be paid attention to when purchasing DC marine air conditioners" and conduct a systematic analysis from multiple dimensions such as voltage compatibility, cooling capacity, energy efficiency ratio, volume structure, noise control, refrigerant type, control method, installation and maintenance convenience, etc., to help you make a wise choice.
1. Voltage specification: the core foundation of DC system
The biggest feature of DC marine air conditioner is that it is directly powered by the ship battery system. Common DC voltages include:
12V DC: suitable for small fishing boats, small sailboats, and leisure boats;
24V DC: suitable for medium-displacement speedboats, business boats, and patrol boats;
48V DC or above: suitable for high-end yachts equipped with solar energy systems or large-capacity energy storage devices.
Before purchasing, be sure to confirm whether the rated voltage of the air conditioner matches the power system on board. Voltage mismatch will cause the equipment to fail to start or trip frequently, or even burn the control board.
It is recommended to choose an air conditioner model that supports wide voltage fluctuations (for example, working in the range of 10.5V–16V) to adapt to the voltage fluctuations of the battery on board during charging and discharging.
2. Cooling capacity (BTU/W): the key to determining the cooling effect
The cooling capacity of the air conditioner is usually measured in BTU/h or watts (W). When purchasing, it should be reasonably matched according to the actual area of the ship's cabin, thermal insulation performance, sunlight intensity, and number of people.
If the cabin ventilation is poor or it sails in high temperature areas all year round, it is recommended to increase the capacity by 20% to ensure sufficient cooling capacity.
3. Energy Efficiency Ratio (EER/COP): An important indicator of energy-saving performance
Energy Efficiency Ratio (EER) is an important parameter to measure the energy efficiency of air conditioners, that is, the cooling capacity that can be generated per unit input power. The higher the EER value, the more energy-saving the air conditioner is.
Generally speaking:
EER ≥ 3.0: high efficiency and energy saving;
EER 2.5–3.0: medium energy efficiency;
EER < 2.5: low energy efficiency, not recommended for long-term use.
On ships with limited power supply and high endurance requirements, high EER air conditioners can reduce power consumption and improve battery utilization efficiency. Some high-end DC air conditioners even support ECO energy-saving mode to reduce energy consumption through intelligent speed regulation.
4. Compressor type and starting current
DC marine air conditioners often use DC variable frequency compressors, which have the following advantages compared to traditional fixed-speed compressors:
Small starting current (no high starting surge);
Fast cooling speed;
Low noise;
Less battery burden.
When purchasing, you should pay attention to whether the starting current of the compressor is within the output capacity of the ship's battery. If the starting current is too high, the system voltage may drop instantly, causing tripping or interfering with the operation of other electronic equipment.
5. Volume and structure: Compact design is more suitable for ship space
The cabin space is limited, so you should pay attention to the body size and installation method of the air conditioner when purchasing. Common structural forms include:
Wall-mounted: suitable for side cabins and window areas;
Embedded/cabinet: suitable for hidden installation;
Integrated/split: choose according to space and maintenance convenience.
It is recommended to give priority to marine air conditioners with anti-salt spray and anti-vibration structural designs to increase the service life in the marine environment.
6. Noise control ability: related to comfort experience
The cabin is an important area for personnel to rest, and noise control of air conditioners is crucial. The DC variable frequency compressor itself has low noise. When high-quality models are running, the indoor noise is usually less than 40 dB, which does not affect sleep and conversation.
Some high-end models are equipped with:
Silent fan;
Multi-layer sound insulation cotton;
Intelligent variable frequency speed regulation system.
If you have high requirements for comfort, you can focus on checking the noise parameters and actual operation feedback of the air conditioner.
7. Refrigerant type: dual consideration of environmental protection and safety
Current mainstream marine air conditioning refrigerants include:
R134a: wide compatibility, but high greenhouse effect potential;
R410a: high refrigeration efficiency and good environmental performance;
R32: new refrigerant, with obvious global promotion trend, high energy efficiency and better environmental protection.
It is recommended to choose a refrigerant model that meets international environmental standards (such as EU RoHS or US EPA certification) to ensure safety of use and regulatory compliance.
8. Control method and intelligent function
DC marine air conditioners are also becoming increasingly intelligent in terms of control methods. Common functions include:
Touch panel temperature adjustment;
Multi-speed wind speed/wind direction adjustment;
Automatic defrosting and dehumidification functions;
Intelligent APP control (supports Bluetooth/Wi-Fi);
Fault self-diagnosis system.
If you want to achieve remote control or centralized management of multiple devices, it is recommended to give priority to models with intelligent network control systems.
9. Installation and maintenance convenience
When purchasing DC marine air conditioners, you should also consider the convenience of later installation and maintenance:
Whether it supports quick pipe connection;
Whether the power supply and drainage interfaces are standard;
Whether the air filter is removable and washable;
Whether detailed installation instructions or after-sales guidance are provided;
Whether there are customized installation brackets/accessories for the corresponding ship type.
In the ship operating environment, an air conditioning system that is easy to install and maintain will greatly reduce the subsequent operation and maintenance costs.
10. After-sales service and brand reputation
Finally, it is recommended to purchase a DC marine air conditioner brand with a good after-sales system and industry reputation. High-quality suppliers usually provide:
1~2 year warranty for the whole machine;
3~5 year warranty for key components;
Quick response technical support team;
Complete accessories supply chain.
When sailing in the ocean or under complex climatic conditions, a trustworthy after-sales system will be your greatest guarantee.
Choosing a DC marine air conditioner is a comprehensive decision involving multiple technical parameters. You need to pay attention not only to whether it can cool, but also whether it is:
compatible with the ship's voltage system;
has sufficient cooling capacity and energy efficiency ratio;
low noise, environmentally friendly refrigerant;
easy installation, intelligent control;
and can operate stably for a long time in actual marine environment.
If you are looking for a DC air conditioning system for yachts, speedboats or commercial ships, please contact us – we are a professional DC marine air conditioning company that supports customized services and provides stable and reliable solutions to help you enjoy coolness and comfort during your sea voyage.
http://www.kmevehicleac.com
kmevehicleac -
