11/11/2026 at 16:47 #6561
https://www.nanos-biomaterial.com/spiral-cutting-and-weld-wire-hypotube-with-hub.html
In minimally invasive medical devices, the structural design of catheter components plays an important role in product performance and assembly compatibility. A spiral cutting and weld wire hypotube with HUB combines a spiral-cut metal tube, a welded core wire, a PTFE coating, and an integrated hub into one customized component. This design brings multiple structural elements together, helping medical device manufacturers meet specific requirements for component configuration, connection strength, and assembly compatibility.
For catheter developers, selecting a suitable hypotube assembly involves more than evaluating the metal tube itself. The relationship between the distal structure, welded wire, coating, and proximal hub also needs to be considered.
1. How Does the Integrated Structure Work?
The main feature of a spiral cutting and weld wire hypotube with HUB is the integration of multiple structural elements into one assembly.
Each component serves a different design purpose:
Spiral-cut hypotube: The spiral-cut section provides a specially configured distal structure. Its cutting pattern can be customized according to the required component geometry and design specifications.
Welded core wire: The core wire is joined to the hypotube through multiple welding points, forming an integrated structural assembly.
PTFE coating: The coating provides a low-friction surface. Its thickness, coating length, and adhesion characteristics are important specification considerations.
Integrated HUB: The hub provides a proximal connection interface, while the strain relief helps manage the transition between connected components.
By combining these elements, manufacturers can develop a more integrated hypotube component rather than sourcing and assembling each structural element separately.
2. Why Are Spiral Cutting and Weld Wire Design Important?
The distal section of a catheter component needs to meet specific structural requirements based on the intended device design.
Spiral cutting introduces a defined pattern into the metal tube, allowing the distal geometry to be customized. The cutting configuration, spacing, and dimensions are important considerations when developing a hypotube for a particular application.
The welded core wire adds another structural element to the assembly. Its connection with the hypotube needs to meet specified bonding strength and dimensional consistency requirements.
For example, the Nanos Biomaterial spiral cutting and weld wire hypotube product specifies a minimum of three distinct welds at the core wire and hypotube joint. The welded connection is also required to withstand a minimum tensile force of 2.5 lbf (11.12 N).
These specifications highlight why cutting geometry and welding quality should be evaluated together when developing customized hypotube assemblies.
3. What Role Does the HUB Play in Component Integration?
The hub is an important part of the overall hypotube assembly because it provides a connection interface for subsequent device integration.
A suitable hub design needs to take several factors into account:
Connection compatibility: The hub dimensions and configuration should match the requirements of the intended catheter assembly.
Bonding strength: The connection between the hub and hypotube needs to meet specified tensile strength requirements. For this product, the Luer-to-hypotube bond must withstand a minimum tensile force of 2.5 lbf (11.12 N).
Strain relief: The transition between the hub and hypotube should be considered to address mechanical stress during handling and assembly.
Leakage performance: The connections between the hub, hypotube, and strain relief should meet the specified leakage requirements.
The Nanos Biomaterial product uses a Lexan HPS7 hub and a Pebax-based strain relief structure. Both bonded and molded hub designs are available, with customized hub shapes according to customer requirements.
4. What Key Specifications Should You Consider When Selecting a Hypotube Assembly?
When sourcing a spiral cutting and weld wire hypotube with HUB, medical device manufacturers should evaluate the complete assembly rather than focusing on a single material or component.
The following specifications are published for this product:
Specification Product Reference Ground wire material 304V stainless steel Coated tube material 304L stainless steel with PTFE coating Hub material Lexan HPS7 Strain relief material 98% Pebax 6333SA01 + 2% blue colorant Hypotube tensile strength 180 ± 15 kpsi Minimum number of welds 3 distinct welds Core wire-to-hypotube weld strength Minimum 2.5 lbf (11.12 N) Luer-to-hypotube bond strength Minimum 2.5 lbf (11.12 N) Hypotube straightness Maximum deflection ≤0.040 in Welded wire straightness Maximum deflection ≤0.160 in PTFE coating thickness 6–13 μm PTFE coating length ≤1600 mm PTFE coating friction ≤3.6 N (average 2.8 N) Coating peeling resistance 1.5–2.5 N Crossing profile 668–696 μm Leakage rate ≤0.05 ATM/sec at 28.5 ATM Leakage test AQL 1.0, C=0 These values are based on the published product specifications. Actual dimensions and configurations should be confirmed against the project drawing and technical requirements.
In addition to material selection, buyers should pay attention to tube straightness, surface condition, welding consistency, coating integrity, and the connection between the hub and hypotube. These details help establish clear acceptance criteria for customized production.
5. What Should Medical Device Manufacturers Consider When Customizing a Hypotube Assembly?
Different catheter projects may require different hypotube dimensions, distal configurations, and connection interfaces. Therefore, customization should be considered during the early design and supplier evaluation stages.
For a spiral cutting and weld wire hypotube with HUB, the following information can help manufacturers evaluate project feasibility:
Required hypotube outer diameter and wall thickness
Overall tube length and coating length
Spiral cutting configuration
Core wire material and welding requirements
PTFE coating type, color, and thickness
HUB shape and connection requirements
Strain relief design
Relevant mechanical and dimensional acceptance criteria
Providing detailed drawings, material requirements, and inspection standards allows the manufacturer to evaluate the component structure and establish a suitable production specification.
http://www.nanos-biomaterial.com
Nanos Biomaterial (Suzhou) Co., Ltd. -
