23/09/2026 at 09:54 #6130
An OEM or private-label generator set order is a different proposition from a standard catalogue purchase: it requires a manufacturer with genuine engineering customisation capability, consistent quality across a production run, and the production capacity to deliver at volume without the unit-to-unit variation that undermines a private-label programme.
MPMC’s Top G-OEM Standing
MPMC is recognised as a Top G-OEM (Generator OEM) in China and has been the largest G-OEM by volume for Perkins and Stamford in recent years, while ranking among the top three G-OEMs for DCEC and Kubota. MPMC also serves as the Chinese National Standards developer for Mobile Hybrid Power Stations — a standing that reflects sustained production volume and engineering credibility with major engine and alternator partners, rather than a claim specific to any single product line.
MPMC factory production line manufacturing Perkins-engined generator sets at scale.
A Manufacturing Base Built for Consistent OEM Production
MPMC Powertech Jiangsu Co., Ltd. operates a 22,000 square-metre workshop plus 4,000 square metres of dedicated office space in Haimen, Jiangsu, with a CNAS-accredited testing centre and end-to-end CNC fabrication and testing integrated with CRM, ERP, PLM, MES, and OA smart-factory systems. This level of process integration is specifically what supports high-volume, high-consistency OEM production for distributors and international partners, since a private-label order depends on every unit in a production run meeting the same specification rather than acceptable unit-to-unit variance.
A Dedicated OEM Subsidiary
Beyond the Haimen facility, MPMC’s group structure includes Agen Powerclub Corp., established in 2020 in Fuan, Fujian, with a 10,000 square-metre workshop, ISO 9001:2015 and CE certification, and end-to-end CNC fabrication and testing dedicated to standardised intelligent diesel generator sets using domestic and Sino-foreign joint-venture engine brands — giving OEM buyers a second, purpose-built production base within the MPMC group specifically for standardised OEM volume rather than high-end customised units.
AGEN SE Series silent generator set, manufactured by MPMC’s Agen Powerclub Corp. subsidiary for standardised OEM production.
What OEM Customisation Actually Covers
MPMC’s distributor and agent partnerships can include OEM customisation and private-label arrangements, exclusive distribution territory arrangements subject to commercial agreement, and full product-line access spanning generator sets, BESS, GSB/GB hybrid power stations, SPK mobile solar arrays, BCH mobile BESS chargers, and MPMC’s lighting tower ranges. For each direct project, MPMC provides an end-to-end service scope covering design consultation, product customisation, factory testing, logistics, and commissioning support, with lead times for both standard and customised products confirmed on a per-order basis rather than published generically.
Facility
Location
OEM Focus
Haimen, Jiangsu
High-end customised and Euro V emission generator sets
Fuan, Fujian
Standardised intelligent diesel generator sets, domestic/JV engine brands
MPMC Energy Tech Corporation
Yangzhong, Jiangsu
Containerised diesel/gas/methanol gensets, BESS/hybrid assembly
Two Production Bases, Two OEM Strategies
A buyer’s OEM requirement usually falls into one of two categories: a high-end, deeply customised configuration, or a standardised, cost-optimised product built to consistent specification at volume. MPMC’s group structure addresses both directly — the Haimen facility focuses on high-end customised intelligent diesel generator sets and specialised variants such as Euro V emission and intelligent cold chain generator sets, while Agen Powerclub’s Fuan facility is purpose-built for standardised OEM volume — letting a buyer route their order to the production base best matched to their actual customisation requirement rather than paying premium engineering time for a standardised order.
Certification Behind the OEM Claim
An OEM partnership is only as credible as the certifications standing behind it. MPMC’s company-level certifications — ISO 9001:2015, ISO 45001, ISO 14001, and CNAS accreditation at the Haimen testing centre — apply across its OEM production, and product-level certifications including CE, TUV, SGS, UL, and Russian Customs Union approval travel with the OEM or private-label unit regardless of the badge or branding a distributor applies to it. A buyer negotiating a private-label arrangement should confirm explicitly which certifications transfer with the OEM product and which, if any, require separate re-certification under the distributor’s own name.
Evaluating an OEM Generator Set Partner
• Confirm the manufacturer’s documented G-OEM standing with major engine and alternator brands, not only a general OEM claim
• Verify factory process integration (CNC, CRM/ERP/MES systems) that supports unit-to-unit consistency at volume
• Ask whether a dedicated standardised-OEM production line exists separately from the manufacturer’s high-end customised range
• Request minimum order quantities and confirmed lead times for your specific configuration
• Confirm private-label and exclusive-territory terms are documented in a formal commercial agreement
• Ask for factory audit access or third-party quality verification before committing to a large-volume OEM order
https://www.mpmc-china.com/
MPMC Powertech Corp. -
