09/06/2025 at 14:32 #3187
In the modern food processing and packaging industry, X-ray inspection equipment, as an important tool to ensure food safety, bears the key responsibility of detecting foreign matter and ensuring product quality. However, many food production companies have encountered a headache in actual use: X-ray food inspection equipment frequently reports false alarms. This not only affects production efficiency, but also increases operating costs and may even affect the company's brand reputation. So, why do X-ray food inspection equipment frequently report false alarms? This article will analyze in depth from multiple angles such as equipment principles, operating procedures, environmental factors, and equipment maintenance to help you find the root cause of frequent false alarms and improve the stability and detection accuracy of the equipment.
1. Understand the working principle of X-ray food inspection equipment
X-ray food inspection equipment mainly penetrates food products through X-rays, and uses detectors to capture the signals after penetration to form images. The system analyzes the abnormal parts in the image through software algorithms to determine whether there are foreign objects (such as metal, glass, stone, bone, etc.). When a suspected foreign object is detected, the equipment will alarm or automatically reject the product.
However, the strength of the X-ray signal is affected by many factors, including the density, shape, moisture content and packaging materials of the food. The algorithm of the equipment must make reasonable judgments on these variables to avoid misjudging normal products as foreign objects.
2. Analysis of common causes of frequent false alarms
2.1 The characteristics of the product itself are complex and changeable
The types of food are diverse, and the density varies greatly
The density and composition of different foods vary significantly. For example, chocolate, meat, and frozen foods have different water contents, which leads to large changes in X-ray transmittance. The equipment mistakenly interprets normal density changes as foreign objects, resulting in false alarms.
Packaging materials affect signal recognition
Certain packaging materials such as aluminum foil, composite film, and thick plastic bags will interfere with X-ray signals, causing image abnormalities and increasing false alarm rates.
Irregular product shape
The uneven surface of the food or the complex internal structure will form image shadows similar to foreign objects, interfering with the judgment of the equipment.
2.2 Improper equipment parameter settings
The detection sensitivity is set too high
The higher the sensitivity, the easier it is for the equipment to detect minor abnormalities, but it is also easier to misjudge normal structures as foreign objects, resulting in frequent false alarms.
The algorithm model is not optimized for the product
Standardized algorithm models may not be suitable for all products, and lack customized adjustments for different food characteristics, affecting accuracy.
Signal acquisition and image processing parameter errors
The time, exposure intensity, image processing filter parameters, etc. of the detector signal acquisition, if set unreasonably, will produce blur or false images, misleading judgment.
2.3 Equipment environment impact
Equipment vibration or unstable installation
Vibration or inaccurate positioning of the mechanical part of the equipment will cause changes in the X-ray detection position, resulting in image deviation and false alarm.
Environmental electromagnetic interference
Electromagnetic wave interference from other equipment in the factory will affect the detector signal and cause false alarms.
Temperature and humidity changes
Extreme temperature and humidity conditions affect the working stability of electronic components, resulting in detection errors.
2.4 Inadequate equipment maintenance and calibration
Sensor aging or contamination
The detector surface has stains or aging, which reduces signal sensitivity and causes data abnormalities.
The equipment has not been calibrated for a long time
Calibration is the key to ensure accurate detection of X-ray equipment. Lack of regular calibration will cause the detection results to deviate from the standard.
The software version is too old or the BUG has not been fixed
The software update is not timely, the algorithm is not perfect, and there are unfixed detection defects.
2.5 Insufficient operator skills
Operation procedures are not strictly implemented
Equipment adjustment and detection procedures are not operated according to standards, affecting the detection effect.
Lack of targeted training
Unfamiliar with equipment characteristics and parameter adjustments, unable to detect and solve false alarm problems in time.
3. How to effectively reduce the false alarm rate of X-ray detection equipment?
3.1 Optimize product design and packaging
Adjust packaging material selection
Try to choose materials with good X-ray transmittance, and avoid overly thick or multi-layer aluminum foil packaging.
Standardize product shape and arrangement
Keep products neatly arranged when designing the production line to reduce image interference caused by irregular shapes.
3.2 Reasonably adjust equipment parameters
Adjust sensitivity according to product characteristics
Combined with actual detection needs, adjust sensitivity to a reasonable range to balance detection sensitivity and false alarm rate.
Optimize algorithms for products
Choose equipment that supports machine learning or AI algorithms, and you can improve the recognition accuracy of specific products through training data.
3.3 Strengthen equipment maintenance and calibration
Develop regular cleaning and maintenance plans
Clean the detector surface, keep the equipment clean, and avoid signal interference.
Strictly implement calibration procedures
Calibrate according to the recommended cycle of the equipment manufacturer to ensure accurate detection.
Update software and firmware in a timely manner
Install the latest version, fix known defects, and use new algorithms to improve detection results.
3.4 Optimize equipment installation and environmental control
The equipment is installed firmly to prevent vibration
Select shock-absorbing measures to ensure stable operation of the equipment.
Control electromagnetic interference in the production environment
Rationally layout factory equipment to reduce signal interference.
Maintain a suitable temperature and humidity environment
Ensure the normal operation of the equipment's electronic components.
3.5 Carry out system training
Regularly train operators on equipment principles, parameter adjustment and troubleshooting.
Establish operating specifications
Develop detailed operating procedures to avoid false alarms caused by human error.
Establish a feedback mechanism
Encourage employees to feedback false alarms and make timely adjustments and improvements.
4. Case sharing: How a food factory solves the problem of false alarms of X-ray equipment
A large food processing company once encountered a false alarm rate of up to 15% for its X-ray detection equipment, which seriously affected production efficiency. After analysis by a professional team, the main problems were found to be:
Uneven product packaging thickness leads to fluctuations in X-ray signals
The equipment sensitivity is set too high and the adaptability is insufficient
The equipment calibration cycle is too long and the sensor surface is slightly contaminated
The company has taken the following targeted measures:
Optimize the packaging process and unify the thickness of packaging materials.
Adjust the sensitivity parameters and retrain the model in combination with the AI algorithm.
Develop a monthly equipment cleaning and calibration plan.
Organize special operator training.
Three months later, the equipment false alarm rate dropped below 3%, production efficiency was greatly improved, and product quality and corporate reputation were guaranteed.
There are many reasons for frequent false alarms of X-ray food inspection equipment, which involve both the parameter setting and maintenance of the equipment itself, and are closely related to product characteristics and environmental conditions. By scientifically adjusting equipment parameters, strengthening maintenance and calibration, optimizing product design and packaging, and improving operator skills, companies can effectively reduce false alarm rates, ensure the accuracy of food safety testing and the stable operation of production lines.
If you also encounter similar problems, it is recommended to systematically check the equipment and production links based on your actual situation, or seek professional technical support to ensure that the X-ray inspection equipment performs at its best.
http://www.vixdetect.net
Shanghai Vixdetect Inspection Equipment Co., Ltd. -
