23/10/2026 at 19:08 #6381
A room that alternates between too warm and too cold is more than a comfort issue. In commercial buildings, repeated temperature swings can lead to occupant complaints, unnecessary equipment operation, and higher energy consumption. When the problem appears in several rooms or returns shortly after a maintenance visit, the cause may lie in the way the HVAC control system responds to changing conditions.
Control valves are an important part of that process. They regulate the flow of chilled or hot water through coils, allowing the heating or cooling output to match the building's demand. When a valve responds poorly, receives an incorrect signal, or operates under unsuitable hydraulic conditions, room temperature can become difficult to maintain.
However, replacing the valve is not always the right first step. A proper diagnosis should consider the valve, actuator, sensor, controller, and water system as a connected whole.
What Temperature Fluctuations Can Tell You
The timing and pattern of a temperature problem often provide useful clues.
If a room repeatedly becomes cold and then warm, the control valve may be opening and closing too frequently. If the room never reaches its setpoint during peak demand, the valve may not be delivering enough water, or the coil may have another problem. If several terminal units begin behaving poorly at the same time, the issue may involve system pressure, pump control, or a shared control setting rather than individual valves.
These symptoms are not definitive diagnoses, but they help narrow the investigation.
Before changing equipment, record the room temperature, setpoint, valve command, actuator position if available, and operating conditions when the problem occurs. A short trend log can reveal whether the temperature change follows a valve movement, a change in water supply conditions, or a shift in room load.
Incorrect Valve Sizing Can Make Control Difficult
A control valve must provide the required flow without becoming excessively sensitive to small changes in position.
An oversized valve can be a particular problem in modulating applications. If the valve is much larger than the circuit requires, the controller may use only a small part of the available travel during normal operation. Small adjustments can then produce relatively large changes in water flow, depending on the valve's characteristics and the pressure conditions.
The result may be repeated overshooting. The controller reduces the cooling output after the room becomes too cold, then increases it again when the temperature rises. Even if the controller is functioning as programmed, the valve may not offer a suitable operating range for the application.
An undersized valve creates a different problem. It may be unable to deliver the design flow when the coil needs maximum heating or cooling. The room temperature then drifts away from the setpoint, especially during periods of high demand.
The correct assessment involves comparing the design flow rate with the valve's published flow coefficient and expected pressure drop. Nominal pipe size alone is not enough to establish whether a valve is suitable.
Differential Pressure Can Change Valve Performance
A control valve does not operate in isolation. Its flow depends on the pressure difference across it, which can change as other valves in the building open and close.
In a variable-flow chilled water system, for example, the opening of multiple terminal valves changes the hydraulic resistance of the network. A valve that operates smoothly under one condition may experience a different pressure drop when system demand changes.
Excessive or unstable differential pressure can make flow regulation more difficult. It may also contribute to noise, poor control, and unnecessary pumping energy.
When several rooms experience temperature fluctuations at similar times, check whether their control valves share a common branch or pressure-control arrangement. Compare the operating conditions when the problem occurs with the system's design assumptions.
Depending on the system, the solution may involve correcting pump control, adjusting the hydraulic arrangement, or introducing appropriate differential pressure regulation. Changing individual valve settings without understanding the wider system can simply move the problem elsewhere.
The Actuator May Not Be Following the Controller
A controller can issue the correct command while the valve itself fails to reach the intended position.
This may happen when the actuator is incorrectly matched to the valve, the supply voltage is unsuitable, the control signal is incompatible, or the actuator cannot provide the required operating force. Mechanical problems, loose connections, and incorrect commissioning can produce similar symptoms.
For modulating control, compare the controller's output with the actuator's actual response. If the controller repeatedly changes its output but the valve position does not follow, investigate the actuator and its connection before adjusting the temperature-control settings.
Also confirm that the valve and actuator are designed to work together. A replacement actuator should match the valve's mounting arrangement, movement, torque or thrust requirements, and control method.
In HVAC applications where the valve must respond to changing room demand, a suitable motorized valve can form part of the solution, but the complete valve and actuator assembly must match the system's operating requirements.
Sensor Placement and Controller Settings Matter Too
Temperature fluctuations are not always caused by the valve. The control loop depends on the accuracy and location of the sensor that measures the room or supply-air temperature.
A room sensor installed near a supply-air outlet, a sunny window, or heat-producing equipment may record conditions that do not represent the occupied space. The controller then adjusts the valve in response to misleading information.
Controller settings can also contribute to instability. An aggressive control response may cause frequent valve movements, while inappropriate proportional or integral settings may lead to overshooting or slow recovery. These settings should be reviewed only after confirming that the sensor, actuator, and valve are working correctly.
A useful diagnostic step is to compare the sensor reading with an independent temperature measurement and review the controller's trend data. If the measured room temperature differs significantly from the control system's reading, changing the valve is unlikely to solve the underlying problem.
A Practical Troubleshooting Sequence
A consistent inspection process helps technicians identify the cause without making several unrelated adjustments at once.
Start with the symptom. Determine whether the room fluctuates around its setpoint, fails to reach the setpoint, or changes temperature at specific times. Check whether the problem affects one terminal unit or several.
Review the control sequence. Compare the temperature reading, setpoint, controller output, and valve command. Where position feedback is available, confirm whether the actuator follows the command.
Check the hydraulic conditions. Verify that the coil receives the required water flow and that differential pressure remains within the relevant equipment limits. Check for blocked strainers, trapped air, and other conditions that can restrict flow.
Inspect the physical equipment. Confirm that the actuator is mounted correctly, the valve moves through its intended range, and the electrical connections match the equipment specifications.
Make one change at a time. After correcting a confirmed fault, observe the system under representative operating conditions. Record the result before making further adjustments.
This sequence helps distinguish a valve problem from a sensor fault, hydraulic issue, or control-setting error. It also reduces the risk of replacing a functioning component unnecessarily.
When Should a Control Valve Be Replaced?
Replacement becomes reasonable when the valve is mechanically damaged, leaking beyond its permitted limits, unable to provide the required flow, or unsuitable for the control task. A valve may also need to be changed if its flow characteristics or pressure rating do not match the actual application.
Before ordering a replacement, document the existing connection size, required flow, operating pressure, fluid temperature, control mode, actuator signal, and available installation space. Confirming these details helps avoid installing a new valve that reproduces the same problem.
Where the system requires modulating control, check the manufacturer's flow characteristics and permitted operating range rather than assuming that every motorized valve can provide stable proportional regulation. The relevant HVAC valve options should be assessed against the application's actual requirements.
Stable Temperature Control Starts With the Whole System
Temperature fluctuations can result from several interacting causes. An incorrectly sized valve, changing differential pressure, an incompatible actuator, a poorly positioned sensor, or unsuitable controller settings may produce similar symptoms.
The most reliable approach is to follow the evidence from the control signal to the physical valve and then to the hydraulic system. Measure actual conditions, compare them with the design requirements, and correct the identified cause before replacing equipment.
When the valve, actuator, sensor, and controller work together under suitable hydraulic conditions, the HVAC system can respond more consistently to changing loads. That is a more effective route to stable indoor temperatures than repeatedly adjusting setpoints or replacing components without a clear diagnosis.
http://www.cd-hvac.com
ChuangDao -
