23/09/2026 at 11:09 #6132
Why Manufacturing Constraints Should Be Considered Before a Metal Part Reaches Production
A metal component can look perfectly reasonable on a CAD screen and still create problems once it reaches the factory floor.
The issue is rarely that the design is fundamentally wrong. More often, a small detail that seemed insignificant during product development turns out to affect tooling, material flow, bending access, inspection, assembly, or production consistency. By the time that problem appears, changing the drawing may mean revising tooling or repeating part of the validation process.
This is why manufacturing considerations are worth bringing into the design discussion earlier than many OEM teams expect. The goal is not to design a part around the limitations of one factory. It is to make sure that the intended geometry can be produced repeatedly without introducing unnecessary cost or complexity.
A Drawing Describes the Part but Not Always How It Will Be Made
Engineering drawings are essential, but a drawing does not automatically define the most practical production route.
A bracket, enclosure panel, mounting plate, or structural support may all have dimensions and tolerances clearly specified, yet the manufacturer still has to determine how the material will be cut, formed, joined, finished, and inspected.
Consider a sheet metal component with several closely positioned holes and bends. On a drawing, each feature may appear individually acceptable. During production planning, however, their relationship may create difficulties with tooling access or material deformation.
The same applies to small flanges, narrow slots, sharp internal corners, and unnecessarily tight tolerances.
A useful design review therefore asks a broader question:
Can the complete geometry be produced consistently, not simply whether it can be produced once?
That distinction becomes increasingly important as production moves from prototypes toward repeat manufacturing.
Small Geometry Decisions Can Have Large Manufacturing Effects
Not every feature on a metal component carries the same manufacturing risk.
A hole placed a little too close to an edge can affect material strength or create problems during forming. A very narrow bend may require a different tool arrangement. An unnecessarily tight radius can make forming more demanding, depending on the material and thickness.
None of these issues necessarily makes a component impossible to manufacture. They simply reduce the number of practical production options.
For OEM projects, it is often useful to identify the features that have the greatest influence on manufacturing before the design is released for tooling.
These can include:
Very small holes or slots
Closely spaced features
Tight bend radii
Deep or narrow formed sections
Large flat surfaces susceptible to deformation
Complex transitions between formed areas
Tolerances that are tighter than the assembly requires
The purpose of reviewing these features is not to simplify the design at any cost. Functional requirements should remain the priority. Instead, the objective is to distinguish between necessary engineering requirements and details that became restrictive simply because they were specified that way.
Tolerances Should Reflect Function
Tolerance is one of the easiest places for a metal part design to become unnecessarily difficult to manufacture.
A common approach is to apply tight tolerances to many dimensions because the design team wants to control variation. In practice, this can create inspection requirements and production constraints that do not contribute meaningfully to the function of the finished product.
A better approach is to identify which dimensions actually affect:
Assembly
Alignment
Movement
Sealing
Electrical contact
Structural interfaces
Interchangeability
These dimensions deserve closer control.
Other dimensions may be allowed a wider range if they do not affect the final assembly.
For a custom metal component, this distinction can give the manufacturer more room to establish an efficient production process while keeping the features that actually matter under control.
Material Choice Is Part of the Manufacturing Process
Material selection is often treated as a product-performance decision, but it also determines how a part can be manufactured.
Two materials with similar strength values may behave differently during bending, stamping, machining, or welding. Their hardness, ductility, thickness, springback, and surface condition can influence the process used to create the component.
This becomes especially relevant when a design moves from prototype to production.
A prototype may be produced through a flexible process that accommodates design changes. Once production volume increases, the manufacturer may consider a more dedicated process such as custom metal stamping for repeatable components.
At that stage, the original material specification needs to be reviewed alongside the production method rather than treated as an independent decision.
Think About Secondary Operations Before Finalizing the Geometry
A metal part rarely ends when its basic shape is complete.
Depending on the product, it may still require:
Deburring
Welding
Threading
Surface treatment
Plating
Anodizing
Powder coating
Assembly
Inspection
Packaging
A design that is easy to fabricate but difficult to finish may not be efficient overall.
For example, two components may require the same powder coating process, but one geometry may be much easier to clean, handle, mask, and inspect before coating. Likewise, a welded assembly may need access for the welding tool that is not obvious from the final CAD model.
Looking at the entire production sequence helps prevent one operation from creating problems for another.
Prototype Production Should Not Hide Mass Production Issues
Prototype manufacturing and production manufacturing serve different purposes.
A prototype is often made to answer questions about fit, function, appearance, or basic performance. The manufacturing method may therefore prioritize flexibility and speed of modification.
Mass production has a different objective. The same component needs to be reproduced repeatedly with controlled variation.
This difference matters when a prototype is made using a process that will not be used for the final production part.
For example, a laser-cut prototype can provide a quick way to evaluate a sheet metal design. Once the geometry is confirmed and demand increases, the production route may shift toward stamping, bending, or a combination of processes.
The transition should be considered before the prototype is finalized.
Otherwise, a design may work perfectly at prototype stage but require substantial engineering changes when production tooling is introduced.
Tooling Decisions Should Follow the Expected Product Lifecycle
Tooling represents a different kind of commitment from ordinary fabrication.
A dedicated tool is developed around a particular component geometry and production requirement. If the product design is still changing significantly, investing in production tooling too early can create unnecessary rework.
This does not mean tooling should always be delayed. It means the timing should correspond to the maturity of the design.
Before tooling begins, an OEM team should have a reasonably clear understanding of:
Final part geometry
Material specification
Critical dimensions
Expected production volume
Surface treatment
Assembly requirements
Inspection criteria
A manufacturing partner can then evaluate whether the proposed design is suitable for the intended production method and whether any modifications would improve manufacturability without changing the component's functional purpose.
Design Reviews Work Better When Engineering and Manufacturing Speak Early
Manufacturability is often discussed as though it belongs entirely to the factory. In reality, it is a shared engineering responsibility.
The product designer understands why the component has its current geometry. The manufacturer understands how that geometry interacts with tooling, equipment, materials, and production sequence.
Bringing both perspectives together can resolve issues before they become expensive.
A productive review does not need to turn into a long list of restrictions. It can focus on a few practical questions:
Which features are functionally critical?
Which dimensions genuinely require tight control?
Which operations will create the final geometry?
What changes when production volume increases?
What secondary processes will the component require?
These questions often reveal opportunities for improvement without changing the basic design intent.
A Production-Ready Design Is More Than a Finished CAD Model
A component is not truly ready for production simply because its dimensions are complete and the CAD model is finished.
Production readiness also involves understanding how the part will move through manufacturing.
That includes the relationship between material, geometry, tooling, tolerances, secondary operations, inspection, and expected volume.
For OEM teams developing brackets, panels, housings, clips, structural components, or other fabricated parts, this broader view can reduce the number of revisions required after the design reaches manufacturing.
It also makes communication with a metal fabrication partner more precise. Instead of discussing whether a supplier can “make the part,” the conversation can focus on the actual engineering requirements and the most suitable production route.
In the long run, that is what turns a manufacturable design into a production-ready one.
http://www.kingsiumetal.com
kingsiu -
