08/09/2026 at 17:41 #6006
A packaging problem often starts quietly.
One product needs a slightly different bag size. Another requires a different finish. A seasonal SKU gets its own format, and a new sales channel asks for another version. None of these decisions seems unreasonable on its own. Six months later, however, a brand may be managing dozens of packaging specifications for products that could have shared a much simpler system.
The issue is not that customization is bad. Custom packaging is often necessary for product protection, branding, and filling requirements. The problem appears when every SKU is treated as a completely independent packaging project.
For growing brands, packaging standardization can create a useful middle ground: enough flexibility to support different products, but enough commonality to reduce unnecessary complexity in purchasing, production, inventory, and quality control.
The Hidden Cost of Too Many Packaging Specifications
Packaging cost is usually evaluated on a per-unit basis. That number matters, but it does not tell the whole story.
A packaging specification also creates work for purchasing teams, warehouse staff, quality inspectors, designers, and production planners. When every product uses a different material structure, bag dimension, closure, or printing specification, these small differences accumulate.
A company with 20 products does not necessarily need 20 completely different packaging structures.
In many cases, several SKUs can share the same basic material family or production format while retaining different dimensions and artwork.
That distinction is important because standardization does not mean making every package identical. It means identifying which characteristics actually need to be different and which ones can remain common.
Where Complexity Usually Comes From
Packaging complexity tends to increase in several predictable areas:
Too many bag sizes for products with similar fill volumes
Different material structures being specified without a clear performance reason
Multiple closure or opening formats across closely related products
Artwork files using inconsistent dimensions and technical specifications
Separate suppliers handling packaging formats that could be consolidated
The result can be higher minimum-order requirements, more inventory, slower purchasing cycles, and greater risk of ordering the wrong packaging for a particular SKU.
Standardization Starts With the Product Family
The easiest place to begin is not the packaging supplier. It is the product portfolio.
Group products according to their physical and commercial requirements rather than their individual names.
For example, a personal-care company may have several liquid products with similar viscosity, filling temperatures, package weights, and distribution conditions. These products may not need completely different packaging structures simply because they have different fragrances or labels.
The same principle applies to dry foods, household products, accessories, and many other consumer goods.
A useful product-family review looks at:
Factor Question to Ask Product weight Which SKUs have similar filling weights? Physical properties Do they have similar viscosity, moisture, oil, or chemical characteristics? Filling method Can they use the same packaging equipment or filling process? Distribution Do they face similar transportation and storage conditions? Shelf requirements Do they require comparable protection during their intended shelf life? Retail format Do they occupy similar shelf or display spaces? This type of grouping can reveal opportunities that are difficult to see when each product is developed separately.
One Packaging Platform Can Support Multiple SKUs
A practical packaging platform might use a limited number of core sizes, with different artwork and product information for individual SKUs.
This approach is particularly useful when a company has a large product range but relatively predictable package dimensions.
For example, instead of developing eight unrelated pouch sizes, a brand might establish three core formats:
Small format: trial products, samples, and low-volume SKUs
Medium format: primary retail products
Large format: family-size or refill products
The exact dimensions depend on the product, but the principle remains the same: create a controlled range rather than an unlimited number of specifications.
A well-planned platform can also simplify artwork development. Designers work from established dielines instead of creating a completely new production file every time a product is launched.
For companies already working with different flexible formats, maintaining clear product specifications across the portfolio is often more valuable than simply reducing the number of packaging designs.
Standardization Can Improve Purchasing Decisions
Procurement teams benefit when packaging specifications are easier to compare.
If every supplier quotation uses a different structure, thickness, dimension, and terminology, price comparisons become unreliable. A cheaper quotation may simply represent a different technical specification.
A standardized purchasing specification should define the characteristics that affect performance and cost.
This might include:
Material structure and thickness
Finished dimensions and tolerances
Printing requirements
Seal specifications
Closure or opening requirements
Packing quantity per carton
Acceptable quality tolerances
Once these parameters are standardized, supplier quotations become much easier to evaluate on an equivalent basis.
That does not mean every supplier must offer exactly the same construction. It means the buyer knows what performance requirements the proposed packaging must meet.
Inventory Is Often Where Standardization Pays Off
Packaging inventory occupies physical space and ties up working capital long before the finished product reaches customers.
A company managing 30 packaging formats has a very different inventory problem from one managing 10 core formats, even if both sell the same number of products.
Excess variety can also create obsolete stock.
A discontinued product may leave thousands of printed bags that cannot easily be reused. Standardizing the structural part of packaging does not eliminate this problem completely, but reducing unnecessary variation can limit the amount of specialized inventory exposed to product changes.
This becomes especially relevant for brands with:
frequent product launches;
seasonal packaging;
short promotional cycles;
rapidly changing product portfolios;
uncertain demand forecasts.
For these businesses, flexibility in the packaging system can be more valuable than maximizing customization for every individual SKU.
Standardization Does Not Mean Giving Up Brand Identity
One concern is that standardized packaging will make products look generic.
That only happens when standardization is applied to the wrong parts of the package.
The structural elements can remain consistent while the visual identity changes through artwork, color, typography, finishes, windows, or other design elements.
A brand may therefore use a common packaging platform while giving each product its own visual identity.
For companies that rely heavily on printed flexible packaging, this separation between structural standardization and visual differentiation can be particularly useful.
The structure provides manufacturing consistency. The artwork provides product-level differentiation.
This is one reason Custom Printed Paper Bags and other customized packaging formats can still fit within a standardized packaging strategy. The printed appearance does not necessarily require every structural specification to be reinvented.
When Standardization Should Not Be Forced
There are situations where using the same packaging structure across products is simply the wrong decision.
A product containing aggressive chemicals may require a different inner sealing layer from a dry consumer product. A high-moisture food may need substantially different barrier performance from a product that is relatively insensitive to humidity.
Similarly, products with different filling temperatures, weights, or transportation conditions may require different mechanical performance.
The goal is therefore not to minimize the number of packaging specifications at any cost.
The better objective is to remove unnecessary variation while preserving differences that have a technical purpose.
A simple decision framework can help:
Situation Standardize? Same product characteristics, different flavors Usually yes Same product weight, different artwork Usually yes Similar products with different chemical compatibility Evaluate separately Different filling temperatures Usually requires validation Major difference in product weight May require different structure Different barrier or shelf-life requirements Evaluate separately Different filling equipment Check machine compatibility first This approach keeps engineering requirements ahead of purchasing convenience.
The Supplier's Role Changes as the Product Range Grows
A packaging supplier should not only manufacture individual orders. For a growing brand, the supplier can also help identify unnecessary variation within the packaging portfolio.
That requires visibility across SKUs.
Instead of asking only, “Can you manufacture this bag?”, procurement teams can ask:
Which parts of our current packaging specification actually need to be unique?
A capable supplier can compare dimensions, materials, sealing requirements, printing methods, and production constraints across different products and identify areas where specifications can be consolidated.
For brands sourcing multiple packaging formats, a broader flexible packaging solution can sometimes be more useful than managing each packaging order as a separate project.
A Better Packaging System Is Not Always the One With the Fewest SKUs
Reducing packaging variety sounds simple, but the real objective is more practical: make the packaging portfolio easier to manage without creating technical compromises.
A well-designed system gives product teams enough freedom to launch new SKUs while giving procurement and operations teams enough consistency to control cost, inventory, and quality.
For a small brand, this may mean establishing a few standard package sizes before the product range becomes complicated. For an established manufacturer, it may mean reviewing existing specifications and identifying formats that have evolved independently over time.
The savings may not come from a dramatic reduction in the price of one bag. They can come from fewer obsolete materials, simpler purchasing, easier quality control, better inventory planning, and fewer packaging decisions that have to be made from scratch.
That is where packaging standardization becomes more than a design exercise. It becomes part of product portfolio management.
