31/07/2026 at 10:24 #5717
Against the backdrop of rapid innovation in the smart wearable industry, products such as TWS earbuds, smart watches, smart rings, and AR/VR devices continue to evolve toward smaller sizes, custom-shaped designs, slimmer profiles, and longer battery life. These trends are driving continuous improvements in lithium battery packaging technologies. For wearable special-shaped batteries, manufacturing has gradually shifted from traditional pouch packaging to mini steel can packaging, which has become one of the mainstream solutions for mass production.
Compared with pouch batteries, special-shaped mini steel can batteries offer higher internal space utilization and improved energy density, helping maximize battery capacity within limited device space. The steel can structure also provides better resistance to extrusion, impact, and puncture while reducing the risk of swelling and electrolyte leakage. In addition, its thermal performance and structural flexibility make it suitable for the irregular internal layouts commonly found in wearable devices.
Precision Electrolyte Filling for Special-Shaped Mini Steel Can Batteries
Electrolyte filling is one of the most critical processes in lithium battery manufacturing. It directly affects battery capacity consistency, cycle life, safety, and production yield.
For special-shaped mini steel can batteries used in wearable devices, the process becomes even more challenging because of narrow internal cavities and extremely small filling ports. Compared with conventional batteries, these characteristics require much higher filling accuracy and process stability.
Traditional piston pumps and similar filling equipment often experience flow pulsation, unstable flow rates, splashing, and reduced metering accuracy over time. During micro-volume filling, these issues can lead to electrolyte splashing, trapped air bubbles, and insufficient wetting of electrodes and separators. As a result, manufacturers may face capacity variation, reduced cycle life, inconsistent product quality, and lower production yields.
FSH-LA Series Linear Metering Pumps
To address these challenges, the FSH-LA series linear metering pumps developed by Guangzhou Ascend Precision Machinery Co., Ltd. are designed for high-precision electrolyte filling of special-shaped mini steel can batteries. The pumps have already been adopted in the production lines of several domestic steel can battery manufacturers.
Using a servo motor-driven precision lead screw linear drive system, the pumps deliver stable, pulse-free electrolyte flow throughout the filling process. This enables accurate dispensing through micro filling nozzles into narrow battery cavities while helping reduce electrolyte splashing and air bubble formation. More uniform wetting of electrodes and separators also contributes to improved cell consistency and cycle performance.
The FSH-LA series incorporates a digital servo closed-loop control system that precisely controls plunger displacement for micron-level micro-volume metering. This helps maintain stable repeatability while reducing filling deviation between cells, improving batch consistency and minimizing electrolyte waste.
The pumps are compatible with the mainstream -95 kPa high-vacuum filling process widely used in lithium battery manufacturing. In addition to wearable special-shaped mini steel can batteries, they can also be applied to coin cells, miniature cylindrical cells, and other customized mini steel can battery formats.
All wetted components are manufactured from high-purity corrosion-resistant ceramic materials, providing excellent resistance to electrolyte corrosion while minimizing the risk of metal ion contamination. The compact integrated structure also simplifies routine maintenance and supports continuous operation in high-volume production environments.
The entire product series complies with explosion-proof safety requirements for lithium battery production workshops, making it suitable for integration into modern battery manufacturing lines.
Looking Ahead
As wearable electronics continue to become smaller and more sophisticated, the demand for higher-precision lithium battery manufacturing processes is expected to grow. Precision electrolyte filling will remain an important factor in improving battery consistency, production efficiency, and overall product reliability.
Guangzhou Ascend Precision Machinery Co., Ltd. continues to focus on precision fluid metering technologies for wearable lithium batteries and other micro lithium battery applications, providing precision filling solutions that support the evolving requirements of advanced battery manufacturing.
https://www.ascendtechs.com/fsh-la-series-linear-metering-pumps.html
Guangzhou Ascend Precision Machinery Co.,Ltd. -
