30/09/2026 at 18:29 #6194
Maintaining a bus engine fuel system often involves more than replacing one visibly worn component. Fuel rails, injectors, high-pressure lines, injection pump parts, return lines, bolts, and sealing washers can all be connected to the same service operation. Identifying these components by their exact part numbers can make maintenance planning and purchasing more organized.
For ZK6138 buses equipped with the WP10.375 engine, the Weichai Bus Engines for ZK6138 1009-00410 Injection Pump Oil Inlet Line, 1112-00158 Fuel Injector, 1128-00027 Fuel Rail, 1128-00249 High-Pressure Fuel Line provides a reference for several important fuel injection components and their associated hardware.
Rather than treating each component as an unrelated spare part, maintenance teams can use the application, part number, and required quantity together when preparing a service order.
Start by Identifying the High-Pressure Fuel Lines
The high-pressure fuel line assembly is one of the main areas to check when servicing the fuel injection system.
The 1128-00249 High-Pressure Fuel Line is listed as a complete six-piece set, with one complete set required for one bus. This makes it different from individual fuel lines used at specific positions within the system.
The parts information also identifies the 1104-00760 High-Pressure Fuel Line and the 1128-00026 High-Pressure Fuel Line as Pump-to-Rail lines. These references should be kept separate from the 1128-00249 complete set when preparing a purchase order.
The description “high-pressure fuel line” by itself is not specific enough for accurate parts identification. A buyer should confirm the exact part number and determine whether the maintenance requirement concerns the complete six-piece set or a particular pump-to-rail line.
The associated fastening and sealing components should also be reviewed. Six 9401-10279 Hollow Bolts and twelve 9401-10278 Sealing Washers are listed for the one-bus requirement.
Having these smaller installation parts available at the same time as the main lines can help avoid delays during service.
Fuel Rail and Bracket Should Be Checked Together
The 1128-00027 Fuel Rail is listed at one piece per bus. Its related 1111-00483 Fuel Rail Bracket is also required at one piece per bus.
The fuel rail forms an important connection within the injection system, so maintenance planning should consider its mounting arrangement as well as the rail itself.
If the existing rail is being removed, the condition of the bracket and associated mounting components can be checked at the same time. This gives maintenance teams a more complete picture of the parts required for the job.
For fleet purchasing, the one-bus quantity is also convenient. If one bus requires one 1128-00027 Fuel Rail and one 1111-00483 Fuel Rail Bracket, the required quantity can be calculated directly from the number of vehicles scheduled for maintenance.
This approach reduces ambiguity when similar fuel system components are being ordered for multiple buses.
Six Fuel Injectors Per Bus
The injector assembly has its own set of application-specific components.
The 1112-00158 Fuel Injector is listed at six pieces per bus. Several related installation components are also specified at six pieces each.
The basic injector-side checklist includes:
1112-00158 Fuel Injector — 6 pieces per bus
1112-00197 Injector Clamp Block — 6 pieces per bus
1112-00196 Injector Spacer — 6 pieces per bus
1112-00380 Injector Protective Cap — 6 pieces per bus
9401-09268 Hex Flange Bolt, M8×35-10.9 — 6 pieces per bus
9401-09269 Hex Flange Bolt, M8×30-10.9 — 6 pieces per bus
The exact installation hardware matters when the service requirement involves replacing or rebuilding the injector arrangement. Ordering only the main injectors and checking the smaller components later can create unnecessary delays if any of the required parts are unavailable.
For a fleet operation, the one-bus quantity also provides a straightforward purchasing formula. Six 1112-00158 injectors are required for each applicable bus according to the supplied parts information.
Injection Pump Components Need Separate Identification
The injection pump side includes several additional parts that should not be confused with the high-pressure fuel line assembly.
The listed components include:
1111-00383 Fuel Injection Pump — 1 piece per bus
1101-04656 Injection Pump Gear — 1 piece per bus
1111-00554 Injection Pump Seal Ring — 1 piece per bus
1111-00247 Injection Pump Flange — 1 piece per bus
The 1009-00410 Injection Pump Oil Inlet Line is also listed at one piece per bus.
The function described by the part name is important here. The 1009-00410 component is an oil inlet line for the injection pump, so it should not be treated as another high-pressure fuel line.
Its supporting hardware includes two 9401-08505 Hollow Bolts, one 9401-07293 Hollow Bolt, two 9401-07304 Bonded Sealing Washers, and four 9401-08206 Sealing Washers.
The supplied parts information also lists seven 9401-08793 Double-Ended Studs and seven 9401-08750 M10 Hex Lock Nuts.
For purchasing departments, recording these components individually by part number can make communication with a spare parts supplier much clearer than using a broad term such as “injection pump parts.”
Don't Forget the Injector Return Line
The injector return side contains additional components that can easily be missed when attention is focused on the main injectors and high-pressure lines.
The 1104-01724 Injector Return Line is listed at one piece per bus. The corresponding parts list includes two 1002-01547 Sealing Washers and one 9401-09882 Hollow Bolt.
Although these components are smaller than the fuel rail or injectors, they form part of the associated fuel system assembly.
When a bus is already scheduled for maintenance, having the required connection and sealing components on hand can help reduce the risk of stopping work because a relatively small part was omitted from the original order.
Why Exact Part Numbers Matter
Bus spare parts can have similar names while serving different positions or functions. A general description may therefore be insufficient for accurate sourcing.
For the ZK6138 WP10.375 application, several important references should be recorded separately. These include 1128-00249 for the complete high-pressure fuel line set, 1128-00027 for the fuel rail, 1112-00158 for the fuel injector, and 1009-00410 for the injection pump oil inlet line.
The 1111-00383 Fuel Injection Pump and 1101-04656 Injection Pump Gear are also included in the supplied one-bus parts information.
Using exact part numbers allows maintenance teams to communicate more precisely with purchasing departments and suppliers. It also helps prevent confusion when different lines or components have similar descriptions.
Planning Quantities for Fleet Maintenance
Part quantities become particularly important when several buses are being serviced.
For one applicable bus, the supplied list calls for six 1112-00158 Fuel Injectors and one complete six-piece 1128-00249 High-Pressure Fuel Line set. The fuel rail and injection pump components listed as one-piece quantities can also be calculated on a per-bus basis.
If a fleet maintenance schedule covers multiple buses, purchasing teams can multiply the one-bus requirement according to the number of vehicles while keeping every component tied to its individual part number.
For example, an order covering five buses would require the corresponding five-bus quantity of one-piece components and thirty 1112-00158 fuel injectors, assuming the same parts requirement applies to all five vehicles.
The calculation should always be checked against the actual maintenance scope because not every service job necessarily requires replacement of every listed component.
A Simple Pre-Order Verification Process
Before purchasing fuel injection parts, maintenance teams can establish a basic verification procedure.
First, confirm the bus model and engine configuration. The application discussed here is the ZK6138 with the WP10.375 engine.
Second, identify the exact part number rather than relying only on the component description.
Third, determine whether the required item is an individual component or a complete set. This is particularly important for the high-pressure fuel lines because the 1128-00249 is specified as a six-piece complete set, while the 1104-00760 and 1128-00026 are identified as Pump-to-Rail lines.
Fourth, calculate the required quantity based on the number of buses and the actual maintenance task.
Finally, review the associated bolts, washers, brackets, clamps, spacers, and other installation components.
This process turns a general repair request into a more detailed purchasing list.
Working With a Bus Parts Supplier
For fleet operators and repair workshops, sourcing several related components from one supplier can simplify communication and shipment coordination.
Guangzhou Hangji Trading Company Limited has specialized in Chinese bus spare parts since 2000. The company operates a 5,000-square-meter warehouse and maintains more than 30,000 SKUs, supported by a team of over 30 professionals.
Its services cover bus spare parts purchasing support, technical communication, product identification, and shipping coordination. The company reports more than 25 years of industry experience and works with core suppliers holding IATF 16949:2016 and ISO 9001:2015 certifications.
For international buyers, shipment arrangements can include express, air, sea, and combined transportation according to the order requirements.
When requesting fuel system parts, providing the ZK6138 bus model, WP10.375 engine information, exact part numbers, and required quantities gives the supplier a clearer basis for checking the order.
Preparing a Complete Fuel System Parts List
A complete parts list can make maintenance preparation more efficient because it connects the major components with their supporting hardware.
Instead of requesting a generic “fuel injection system,” buyers can identify the high-pressure line set, fuel rail, injectors, injection pump components, oil inlet line, return line, bolts, and sealing washers individually.
For this application, the main references include the 1128-00249 six-piece high-pressure fuel line set, 1128-00027 Fuel Rail, six 1112-00158 Fuel Injectors, and 1009-00410 Injection Pump Oil Inlet Line.
The associated components should then be checked against the actual repair requirement and the number of buses scheduled for service.
This method is useful not only for one repair job but also for fleet maintenance planning. Keeping the application, part number, description, and quantity together provides a clearer purchasing record and reduces the chance of overlooking related components.
Final Thoughts on ZK6138 WP10.375 Parts Sourcing
Fuel system maintenance requires accurate identification because several components operate as part of the same assembly. High-pressure lines, fuel rails, injectors, injection pump parts, return lines, and sealing hardware may all need to be reviewed depending on the repair scope.
For ZK6138 buses using the WP10.375 engine, the Weichai Bus Engines for ZK6138 1009-00410 Injection Pump Oil Inlet Line, 1112-00158 Fuel Injector, 1128-00027 Fuel Rail, 1128-00249 High-Pressure Fuel Line provides a useful reference for organizing these related components by part number and one-bus quantity.
For buyers preparing a maintenance order, confirming the vehicle application first, checking every part number, distinguishing complete sets from individual components, and reviewing the related installation hardware can make the sourcing process more systematic.
With the required technical information prepared in advance, Guangzhou Hangji Trading Company Limited can use the parts list to assist with product identification, order coordination, and shipment arrangements for ZK6138 WP10.375 bus fuel system components.
http://www.hjbuspart.com
Guangzhou Hangji Trading Company Limited -
