13/04/2026 at 10:11 #4871
Tetrakis(hydroxymethyl)phosphonium sulfate solution (THPS), CAS 55566-30-8, is a highly versatile industrial chemical widely recognized for its strong bactericidal performance, low toxicity, and environmental compatibility. It is a clear, colorless viscous liquid with acidic properties and excellent water solubility, making it suitable for a wide range of industrial applications.
As global industries move toward safer and more sustainable chemical solutions, THPS has become an important alternative to traditional high-toxicity biocides. Its applications now span oil and gas production, water treatment, paper manufacturing, flame retardant synthesis, and leather processing.
Chemical Profile of THPS
THPS, also known as octakis(hydroxymethyl)diphosphonium sulfate or tetrakis(hydroxymethyl)phosphonium sulfate (2:1), has the molecular formula C8H24P2S.
Its key chemical characteristics include:
High water solubility, enabling easy integration into aqueous systems
Viscous liquid form with stable handling properties
Acidic nature that enhances antimicrobial activity
Good thermal stability under moderate industrial conditions
These properties allow THPS to perform reliably in continuous industrial operations while maintaining consistent biocidal efficiency.
Applications in Oil and Gas Operations
In the oil and gas industry, microbial contamination is a major operational challenge, particularly due to sulfate-reducing bacteria that generate hydrogen sulfide and accelerate pipeline corrosion.
THPS is widely used as a high-performance biocide in oilfield water systems. Its mechanism involves disrupting microbial cell membranes and interfering with metabolic processes, resulting in rapid bacterial elimination.
Key advantages in oilfield applications include:
Effective control of sulfate-reducing bacteria
Reduction of biofilm formation in pipelines and equipment
Compatibility with corrosion inhibitor systems
Performance stability in varying temperature and flow conditions
Because of its low toxicity and environmental acceptability, THPS is increasingly favored in modern oilfield chemical programs that must comply with strict environmental regulations.
Water Treatment Applications
THPS plays a significant role in industrial and municipal water treatment systems due to its broad-spectrum antimicrobial activity and environmentally friendly profile.
It is effective against bacteria, algae, and fungi, helping prevent biofilm formation in cooling towers, circulating water systems, and storage tanks.
Compared with traditional chlorine-based biocides, THPS offers several advantages:
Lower formation of harmful disinfection by-products
Strong performance at low dosage levels
Compatibility with green chemistry regulations
Reduced environmental impact in wastewater discharge
In addition, THPS helps improve heat exchange efficiency by controlling microbial fouling and reducing system scaling risks.
Applications in the Paper and Pulp Industry
In paper manufacturing, microbial contamination can lead to slime formation, equipment corrosion, and reduced product quality. THPS is widely used to control these issues throughout pulp processing and water circulation systems.
Its benefits in this sector include:
Prevention of bacterial and algal growth in process water
Reduction of microbial-induced corrosion in machinery
Improved operational stability in pulp production systems
Lower environmental impact compared to traditional biocides
By maintaining cleaner systems, THPS contributes to better paper quality and longer equipment lifespan.
Role in Flame Retardant Synthesis
Beyond its biocidal applications, THPS is also used as a precursor in the production of flame retardant materials.
In polymer systems, phosphorus-containing compounds derived from THPS promote char formation during combustion. This creates a protective barrier that slows flame spread and improves fire resistance.
Applications include:
Flame-retardant coatings
Textile treatment formulations
Polymer resins for construction and electronics
As global regulations increasingly restrict halogenated flame retardants, THPS-based alternatives are gaining importance as safer and more sustainable solutions.
Applications in Leather Tanning
THPS is also used in leather processing as both a tanning agent and antimicrobial additive.
It interacts with collagen fibers in hides, improving:
Leather durability
Softness and flexibility
Resistance to microbial degradation
Additionally, its antimicrobial properties help prevent spoilage during storage and transportation. The use of THPS in leather tanning also reduces reliance on heavy metals and minimizes wastewater pollution, supporting more sustainable production practices.
Export and Supply Chain Considerations
For international markets, THPS must be handled with attention to regulatory compliance, packaging, and logistics.
Key considerations include:
Compliance with REACH, TSCA, and local chemical regulations
Provision of MSDS and certificates of analysis
Use of corrosion-resistant and sealed containers for transport
Proper labeling of concentration and handling instructions
Although THPS is chemically stable and does not typically require cold-chain transport, protection from extreme temperatures is important to maintain product quality during shipment.
Environmental and Safety Profile
One of the key advantages of THPS is its favorable environmental and safety profile.
It has:
Low toxicity compared to traditional biocides
Low bioaccumulation potential
Ability to degrade into non-toxic by-products under wastewater treatment conditions
Standard chemical safety practices are still required, including the use of protective equipment and proper ventilation during handling. However, its overall risk profile is significantly lower than many conventional industrial biocides.
Quality Standards and Compliance
The performance of THPS depends heavily on product quality and manufacturing consistency.
Reputable suppliers ensure compliance with:
ISO quality management standards
GMP production systems
REACH registration and international chemical regulations
Batch testing for concentration and microbial efficacy
These standards are essential for ensuring stable performance across industrial applications and facilitating global trade.
Market Trends and Future Outlook
The demand for CAS 55566-30-8 THPS is expected to continue growing due to increasing requirements in water treatment, oilfield chemistry, and sustainable industrial processes.
Key market trends include:
Rising demand for eco-friendly biocides
Expansion of oil and gas infrastructure in emerging markets
Increasing adoption of green chemistry principles
Development of multifunctional chemical formulations
Future innovations may focus on more concentrated formulations, improved stability systems, and multifunctional blends that combine biocidal and corrosion-inhibiting properties.
Tetrakis(hydroxymethyl)phosphonium sulfate (THPS, CAS 55566-30-8) is a highly versatile and environmentally responsible industrial chemical. Its strong antimicrobial performance, low toxicity, and broad application range make it essential in oil and gas production, water treatment, paper manufacturing, flame retardants, and leather processing.
As industries continue to prioritize sustainability and regulatory compliance, THPS is expected to play an increasingly important role in modern chemical applications. For global users, understanding its properties, applications, and handling requirements is key to maximizing performance while maintaining environmental and operational safety.
http://www.dico-hbwk.com
dico hbwk -
