14/07/2025 at 14:09 #3527
Polyester webbing sling is a flexible sling commonly used in lifting and hoisting operations. With its advantages of light weight, high strength, no damage to objects, and convenient operation, it is widely used in machinery manufacturing, logistics warehousing, port transportation, construction and other fields. Although polyester webbing slings have excellent performance, they are fiber products and are sensitive to environmental conditions. If they are not stored properly, they may lead to decreased strength, surface damage, or even premature scrapping, which seriously affects safety and economy. Therefore, it is very important to master the correct storage method of polyester webbing slings.
This article will systematically explain how to properly store polyester webbing slings from multiple aspects such as why we should pay attention to storage, storage environment requirements, specific operation methods, common misunderstandings and maintenance suggestions, so as to help enterprises and individuals better manage and extend the service life of polyester webbing slings.
1. Why should we pay attention to the storage of polyester webbing slings?
Many people think that polyester webbing slings are durable and not easy to damage. They are often thrown away after the lifting is completed, leaving them exposed to moisture, sun exposure, oil, chemicals and even sharp objects. Little do people know that these improper storage behaviors can easily cause the following problems:
Reduced strength: Exposure to sunlight, high temperature or chemical corrosion will destroy the molecular structure of polyester fibers, resulting in reduced load-bearing capacity.
Surface wear: Contact with rough or sharp ground will scratch the surface fibers, leaving hidden dangers that are difficult to detect with the naked eye.
Mold and deterioration: Long-term exposure to moisture and storage in a closed and humid environment can easily breed mold, affecting appearance and toughness.
Shortened life: Frequent exposure to adverse environments may cause polyester webbing slings to age prematurely, and the scrap cycle is greatly shortened.
Therefore, scientific and reasonable storage of polyester webbing slings is an important part of ensuring safe operation and reducing costs.
2. Storage environment requirements for polyester webbing slings
Correct storage must first create a suitable environment. The storage environment of polyester webbing slings should meet the following requirements:
Dry and ventilated: The slings should be stored in a dry and ventilated warehouse to avoid long-term moisture or exposure to high humidity.
Shade and sun protection: Avoid direct sunlight or exposure to strong ultraviolet rays to prevent aging of polyester fibers.
Avoid high temperature: Do not store the sling near high temperature or heat sources, such as steam pipes, radiators, and drying equipment. It is recommended that the ambient temperature be controlled between -40℃ ~ +60℃.
Keep away from chemicals: Polyester is sensitive to acids, alkalis, and certain organic solvents. It should be stored separately from chemicals such as paints, acids, alkalis, and solvents to prevent corrosion.
Avoid heavy pressure and extrusion: The sling should be placed flat or hung to avoid being pressed by heavy objects to prevent deformation or damage.
Avoid contact with sharp objects: When storing, make sure there are no sharp objects such as nails and blades around to prevent scratches and cuts on the surface.
3. Specific storage methods for polyester webbing slings
In addition to environmental requirements, you also need to master some practical storage skills and specifications.
Clean before storage: After the lifting work is completed, check and clean the sling first. Use a clean soft brush or wet cloth to wipe off the dirt, dust, and oil stains on the surface. If there are chemical residues, rinse with clean water and dry them in time.
Natural drying: If the sling is damp or not dry after washing, it must be placed in a cool and ventilated place to dry naturally before storage. Do not use high temperature drying or exposure to the sun.
Hanging is appropriate: It is best to hang the sling on a special sling rack or hook, and avoid stacking it on the ground to prevent indentation, curling or moisture.
Classification and placement: Slings of different specifications, lengths, and load-bearing capacities should be classified and placed, and marked for easy access next time to prevent misuse.
Regular inspection: The condition of the sling should be checked regularly during storage. If wear, cracking, deformation, chemical corrosion, etc. are found, they should be handled or scrapped in time.
4. Common misunderstandings in the storage of polyester webbing slings
Many companies and users are prone to the following misunderstandings in actual operations:
Misunderstanding 1: Throwing it on the ground at will
Many people throw the sling on the ground after use, which is easy to be contaminated with mud, oil, or even crushed by vehicles.
Misconception 2: Hanging outdoors for a long time
Some people hang the slings on the steel frame in the open air for easy access. Long-term exposure to wind, sun and rain will seriously damage the slings.
Misconception 3: Mixing with chemicals
Some warehouses have limited space. Putting polyester webbing slings together with paint, acidic solutions, etc. is easy to be corroded.
Misconception 4: Rolling into a dead knot or knotting
In order to save space, some people tie or wrap the slings into a dead knot for storage, which will cause the slings to be locally stressed for a long time and affect the strength.
Misconception 5: Stacking too high and heavy objects pressing on the top
The slings are placed at the bottom of the cargo pile and are squeezed or deformed by heavy objects for a long time, which is not conducive to their restoration to their original state.
Avoid these misunderstandings to better protect the slings.
5. Daily maintenance suggestions for polyester webbing slings
In addition to correct storage, you also need to pay attention to daily maintenance to increase the service life of the slings.
Regular inspection: Check the inventory slings at least once a quarter and scrap them in time if any problems are found.
Establish files: Establish a use file for each sling, record the time of use, frequency of use, maintenance, etc.
Trainers: Regularly train operators on the use and storage of polyester webbing slings to improve safety awareness.
Establish a system: The company should formulate a unified sling management system and storage specifications to avoid arbitrary human operation.
Although the polyester webbing sling is small, it is one of the key links in the safety of lifting and hoisting. A good storage environment and correct storage method can not only extend its service life, but also avoid the occurrence of safety accidents. The core of the correct storage of polyester webbing slings is: dry ventilation, sun protection and moisture protection, stay away from chemicals, avoid squeezing, regular inspection, and standardized management.
We recommend that every company and individual using polyester webbing slings should attach great importance to its storage issues and formulate detailed management specifications to ensure that the slings can escort your work in a safe and efficient state.
"Proper storage of a sling is to protect a safety." I hope that the introduction of this article can provide practical guidance and help for your work, so that every lifting operation will be more secure and smooth.
As a professional polyester webbing sling enterprise, we are well aware of the importance of proper storage to ensure the safety performance and extend the service life of the sling. We not only provide customers with high-quality polyester webbing sling products, but also strive to spread standardized storage and maintenance knowledge to help users avoid damage and accidents caused by improper environment. Through scientific management and professional guidance, each sling is always kept in the best condition to ensure the safety of customers' lifting. If you have any questions during storage or use, we will also provide professional support and solutions at any time.
http://www.reliablesling.com
reliablesling -
