26/08/2026 at 15:51 #5906
Why Low Nitrogen Background Matters for NV Diamond Laboratory Work
For research institutes and universities working with nitrogen-vacancy (NV) center quantum diamond, the purity of the starting substrate is often the deciding factor between a stable, reproducible experiment and a frustrating cycle of inconsistent results. ViQium Technologies Co., Ltd., a company focused on the exploration, scalable fabrication, and industrial application of quantum diamonds and emerging two-dimensional phosphorus-based materials, addresses this need directly through its High Purity Diamond product line, engineered specifically to support single and shallow NV-center fabrication where a low nitrogen background is essential.
High Purity Diamond: The Substrate Foundation
ViQium’s High Purity Diamond product is defined by three core parameters: nitrogen content below 5 ppb, boron content below 1 ppb, and carbon-12 enrichment of 98.9%. These specifications establish a substrate environment with minimal background nitrogen impurities, which is critical for laboratories seeking to fabricate single NV centers or shallow NV centers without interference from unwanted nitrogen defects elsewhere in the crystal lattice. Beyond NV-center fabrication, this material is also widely used in semiconductors and electronics as well as optical windows, reflecting the broad applicability of a controlled, low-background crystal foundation.
The carbon-12 enrichment component is particularly relevant for laboratories pursuing long coherence times, since isotopic purity reduces spin-bath noise from carbon-13 nuclei. This positions the High Purity Diamond as a starting material for downstream single NV diamond fabrication, where coherence performance depends heavily on the cleanliness of the surrounding lattice.
From Substrate to Single NV Diamond Performance
Building on this low nitrogen background foundation, ViQium’s Single NV Diamond product delivers documented performance suited for demanding laboratory applications. The product parameters include a T₂ of 300–600 μs measured by Spin Echo, a T₂ of 1 μs measured by FID*, and an NV density of 10–10,000 units per 10⁴ μm². These parameters make the Single NV Diamond product applicable to quantum computing, quantum networking, quantum simulation, high-resolution quantum sensing, and single-molecule NMR—use cases that depend on precise control over individual NV centers rather than dense ensembles.
Laboratories can select from multiple standardized product codes depending on crystal orientation and dimensions: SNV100F12 in the <100> orientation at 2×2×0.5 mm, SNV100F13 in the <100> orientation at 3×3×0.5 mm, and two <111>-oriented variants under the code SNV111F12 at both 2×2×0.5 mm and 3×3×0.5 mm dimensions. This range allows research teams to match crystal orientation to their specific experimental geometry without redesigning their measurement setup around a single fixed format.
Customization and Characterization Support
Recognizing that laboratory research often requires more than an off-the-shelf product, ViQium provides customer services spanning product customization and factory calibration and characterization data for its Single NV Diamond and related quantum materials series. This means laboratories receive not only the physical diamond sample but also documented performance data generated during manufacturing, supporting the reproducibility that research customers consistently prioritize.
This approach directly responds to a challenge commonly faced by research institutes and universities: unstable experimental results and insufficient reproducibility that can limit research efficiency and progress. By pairing low nitrogen background materials with calibration data, ViQium aims to reduce the uncertainty that first-time or experienced NV-center researchers face when validating fundamental physics experiments.
Addressing Common Laboratory Selection Challenges
First-time users of NV diamond materials frequently encounter difficulty selecting the optimal crystal orientation and NV center concentration for their specific experimental requirements, given the absence of clear reference standards. ViQium addresses this through a comprehensive NV Diamond Selection Guide paired with professional online consultation services. Products are categorized according to application requirements—including magnetic field sensing, magnetic imaging, and temperature sensing—so that laboratories can select the appropriate material without needing to purchase multiple samples for side-by-side comparison.
A related challenge involves limited access to small-batch customization alongside high-performance material parameters. ViQium combines flexible small-batch customization with in-house fabrication capability, allowing crystal orientation, NV concentration, sample dimensions, and microstructure processing to be tailored to specific laboratory requirements. Standard products are delivered within 28 days, while conventional customized products are delivered within 45 days, giving research teams a predictable timeline for planning experiments.
Integrated ODMR Testing Support
Many suppliers in this space focus solely on diamond material sales without offering integrated optically detected magnetic resonance (ODMR) testing solutions, leaving laboratories to assemble their own experimental workflow. ViQium’s technical team combines expertise in diamond material engineering with quantum measurement technologies, offering an integrated solution that includes diamond samples, optical components, and system configuration support. This covers the full ODMR workflow—optical alignment, signal acquisition, and magnetic field calibration—along with supporting test components, experimental parameters, and operation procedures, allowing customers to obtain both materials and testing solutions from a single provider.
The Underlying Quantum Principle
The performance of low nitrogen background NV diamond materials is rooted in the physical operation of the NV center itself. An NV center functions through three fundamental steps: optical initialization, where a green laser prepares the NV center’s quantum state; quantum manipulation, where a precisely tuned microwave field controls the spin states; and optical readout, where the NV center is excited again to produce red fluorescence whose intensity reveals the final quantum state. A low nitrogen background reduces competing defect signals during this process, supporting cleaner optical initialization and readout cycles—an important consideration for laboratories conducting sensitive measurements of magnetic fields, temperature, or electric fields.
Supporting the Full Research Journey
ViQium’s service framework for NV center quantum diamond materials covers requirement alignment, solution design, sample validation, delivery implementation, and application support. This end-to-end structure is designed specifically with research institutes and universities in mind, since these customers typically prioritize technical performance, product pricing, delivery timelines, and ongoing technical support throughout their experimental work. Tailored technical guidance covering material characteristics, operating procedures, and key experimental considerations further supports laboratories in achieving effective material utilization and reliable experimental reproducibility.
For laboratories evaluating NV diamond materials with a genuinely low nitrogen background, ViQium’s High Purity Diamond and Single NV Diamond product lines—backed by calibration data, flexible customization, and integrated ODMR support—offer a structured pathway from substrate selection through to functioning experimental setup.
https://en.viqiumtech.com/
ViQium Technologies Co., Ltd. -
