26/08/2026 at 16:35 #5908
Agricultural machinery frequently operates in punishing conditions—dust, mud, moisture, extreme temperature swings, and constant mechanical vibration. Lighting components mounted on tractors, harvesters, and other field equipment must therefore be engineered differently than lighting used in typical automotive settings. This is the core reason why the square LED work light category has become a distinct product segment, and why manufacturers with specialized industrial lighting expertise, such as Shenzhen Aurora Technology Co., Ltd. (brand name: Aurora), have developed dedicated product lines to meet this need.
Why Square LED Work Lights Matter for Agricultural Machinery
Agriculture is explicitly identified as one of the industries served by Aurora, alongside Automotive, Powersports, Marine, Industrial, and Mining sectors. Within agricultural equipment—tractors and harvesters in particular—lighting is not a cosmetic add-on but a functional necessity for operators who often work in low-light conditions, early mornings, or during nighttime harvest windows. A square LED work light provides a wide, even light distribution pattern that suits equipment surfaces and mounting brackets designed around rectangular or square cutouts, making it a practical shape choice for many machinery applications compared to round alternatives.
Engineering Built for the Field
The demands placed on agricultural lighting go beyond simple brightness. Equipment lighting must survive continuous exposure to water, dust, chemical residue, and mechanical shock while maintaining consistent output over long operating hours.
Ingress Protection and Sealed Construction
Aurora’s industrial work light series, which includes several square-format models, is built with a potted and screwless design. This construction method eliminates gaps where moisture or particulates could otherwise penetrate the housing, and it directly supports the IP68 and IP69K ingress protection ratings referenced across the company’s industrial lighting products. IP68 and IP69K ratings indicate that a unit is rated for both total submersion and exposure to high-pressure, high-temperature washdown—conditions that agricultural machinery regularly encounters during cleaning and field operation. Beyond sealing, the products also incorporate protection functions such as reverse polarity protection, overcurrent protection, temperature protection, and anti-static protection, which are described features on models like the ALO-W-4-L31B1-13 and ALO-R-5-L30B1-14.
Vibration and Thermal Resilience
Aurora’s broader industrial and agricultural lighting line is documented as tested for 10g/5-500Hz vibration resistance, a specification aimed at withstanding the heavy engine and drivetrain vibration typical of tractors, excavators, and similar equipment. Temperature control is also built into the square work light models, helping regulate LED performance across varying ambient conditions. These lights are further designed for a wide voltage range supporting 9V-32V DC systems, which is the electrical range commonly found in tractors and other heavy machinery, allowing for straightforward electrical integration without additional voltage conversion equipment.
Product Lineup: Square LED Work Lights from Aurora
Aurora’s Industrial Work Light category includes several square-format models, each positioned for slightly different scale and output requirements, all sharing the same core protective architecture.
The ALO-W-4-L31B1-13 is described as a large square industrial work light. It uses a white main light rated at 6000 ±500K color temperature, with 13 pieces of 3030 2W LEDs. At a 13.2V DC input, it delivers an illuminance of 800 lx ±10% at a 6-meter distance, with a photoelectric test reading of 3000 lm ±15% at the one-minute mark and 2700 lm ±15% at the 30-minute mark, reflecting realistic sustained output rather than only an initial peak figure. Its electrical draw is recorded at 25.4W ±15% at one minute and 24.3W ±15% at 30 minutes, with overall dimensions of 104 x 133.5 x 29.3 mm. It ships as hardware with 03-1 packaging and bare wire configuration.
The ALO-W-4-L34B2-12 shares the same large square form factor but is positioned as a silk-screen version, using 12 pieces of the same 3030 2W LED type. Its 6-meter illuminance is rated at 560 lx ±10%, with photoelectric output of 2300 lm ±15% at one minute and 2100 lm ±15% at 30 minutes. Electrical specifications show 20.8W ±15% at one minute and 20W ±15% at 30 minutes, with identical housing dimensions of 104 x 133.5 x 29.3 mm to its counterpart, offering equipment designers a visual or output variation within the same physical footprint.
For applications requiring a smaller form factor, the ALO-W-3-L33B2-5 is positioned as a small square industrial work light. It uses 5 pieces of 3030 2W LEDs, producing 180 lx ±10% illuminance at 6 meters and photoelectric readings of 1200 lm ±15% at one minute and 1100 lm ±15% at 30 minutes. Electrically, it draws 10.9W ±15% at one minute and 10.6W ±15% at 30 minutes, in a compact 100.4 x 74.8 x 30.7 mm housing—suitable for mounting locations on agricultural equipment where space is limited.
All three models retain the same underlying protective functions: reverse polarity protection, overcurrent protection, temperature protection, and anti-static protection, combined with the potted, screwless build that supports their IP68/IP69K ratings.
Manufacturing Quality and Certifications
These square LED work lights are produced within a manufacturing environment supported by CNC machining, SMT lines, and X-ray inspection systems, according to Aurora’s stated production capabilities. The company operates under a Quality Management System framework that includes IATF 16949 certification for automotive-grade processes, ISO 9001 for general quality management, ISO 14001 for environmental management, and ISO 45001 for occupational health and safety. Product-level compliance references include CE certification and RoHS compliance, alongside E-mark and SAE compliance for markets requiring those standards. Aurora also holds over 200 innovation patents, reflecting a sustained internal research and development effort behind its lighting product lines. The company was founded in 2011 and currently operates a 35,000 square meter industrial park with more than 400 employees, based at Aurora Tech Park in Pingdi Street, Longgang District, Shenzhen.
Selecting the Right Square LED Work Light for Agricultural Use
When evaluating a square LED work light for tractors, harvesters, or similar agricultural machinery, several factors from Aurora’s documented specifications are useful reference points: the ingress protection rating (IP68/IP69K) for washdown and submersion resistance, the voltage compatibility range (9V-32V DC) for electrical system alignment, the vibration test rating (10g/5-500Hz) for mechanical durability, and the sustained photoelectric output figures at both the one-minute and 30-minute marks, which offer a more complete picture of real-world performance than a single peak brightness value. Housing dimensions and mounting footprint should also be matched to the equipment’s existing bracket or panel cutout, since Aurora offers both large and small square formats within the same protective design philosophy.
For agricultural operators and equipment manufacturers seeking a lighting solution engineered specifically around the sealing, vibration, and voltage requirements of field machinery, Aurora’s square LED work light lineup—spanning the ALO-W-4-L31B1-13, ALO-W-4-L34B2-12, and ALO-W-3-L33B2-5—represents a documented, specification-driven option within Shenzhen Aurora Technology’s broader Industrial, Agricultural & Mining lighting category.
https://www.szaurora.com/
Shenzhen Aurora Technology Co., Ltd. -
