23/09/2025 at 16:14 #3987
For wine lovers and hospitality professionals alike, serving wine at the perfect temperature, with consistent pour control and minimal waste, is key to an exceptional experience. The SC-4C-A Wine Dispenser is designed to deliver exactly that—combining precise dispensing technology with elegant presentation.
Aidewo, a company dedicated to the R&D and production of IoT-enabled smart beverage equipment, has engineered the SC-4C-A to integrate innovation, convenience, and style, making it a perfect solution for restaurants, wine bars, hotels, and even home connoisseurs.
Why Choose the SC-4C-A Wine Dispenser?
IoT Connectivity: Remote monitoring, settings adjustment, and performance tracking via smart systems.
Temperature Control: Keeps wines at their optimal serving temperature for peak flavor and aroma.
Portion Control: Reduces waste while ensuring consistency in every pour.
Preservation Technology: Extends wine freshness, allowing bottles to remain open for longer without quality loss.
Elegant Design: Fits seamlessly into both professional and home environments.
Step-by-Step Setup Guide
Step 1: Unpack and Inspect
Carefully remove the SC-4C-A from its packaging.
Inspect for any visible damage during transportation.
Confirm that all accessories (power cord, tubing, cleaning kit, user manual) are included.
Step 2: Choose an Installation Location
Select a stable, level surface away from direct sunlight and heat sources.
Ensure adequate ventilation around the unit for proper cooling.
Step 3: Connect Power
Plug the power cord into a grounded electrical outlet.
Make sure the outlet matches the voltage requirements specified in the manual.
Step 4: Set Up Wine Bottles
Open the bottle compartment and securely attach each bottle to its corresponding dispensing tube.
Ensure airtight seals to maintain preservation performance.
Step 5: Calibrate Portion Sizes
Using the control panel, set the desired pour volumes (e.g., tasting size, half glass, full glass).
Test pour to verify accuracy and adjust settings as needed.
Step 6: Adjust Temperature Settings
Select the recommended serving temperature for each wine type (red, white, sparkling).
Allow the unit time to reach and stabilize at the set temperature.
Step 7: Connect to IoT System (Optional but Recommended)
Follow the app or software instructions to connect your SC-4C-A to your Wi-Fi network.
Enable remote monitoring and data logging for usage insights.
Step 8: Test and Fine-Tune
Perform several test pours to confirm smooth operation, correct temperature, and consistent volume.
Make final adjustments as necessary.
Maintenance Tips for Longevity
Daily: Wipe the exterior with a soft, damp cloth.
Weekly: Run the cleaning cycle to flush the dispensing lines.
Monthly: Inspect seals, tubing, and nozzles for wear and replace if needed.
Annually: Schedule a professional inspection if used in a commercial environment.
Frequently Asked Questions (FAQ)
Q1: Can the SC-4C-A dispense both red and white wines at the same time?
Yes, the unit features independent temperature controls for multiple bottles, allowing you to serve different wine types simultaneously.
Q2: How long does wine stay fresh?
Thanks to the nitrogen system, freshness is preserved for weeks after opening
Q3: Is the IoT connection necessary for operation?
No, the dispenser works independently, but IoT connectivity provides additional monitoring and control features.
Q4: How do I clean the dispensing system?
The SC-4C-A includes a cleaning kit and automated flush program for easy maintenance.
Q5: Can I use it at home?
Absolutely. While designed for professional use, many wine enthusiasts enjoy the SC-4C-A in private cellars and kitchens.
Aidewo: Leading the Way in Smart Wine Service Innovation
As a pioneer in IoT-enabled smart beverage solutions, Aidewo focuses on merging technology with user experience. Their dedication to precision engineering, quality materials, and intelligent design ensures that every product, including the SC-4C-A, meets the needs of both hospitality professionals and wine lovers.
Setting up the SC-4C-A Wine Dispenser is straightforward, but the impact it makes on wine service is profound—offering consistent pours, perfect temperatures, and extended freshness. With Aidewo’s expertise in smart beverage technology, you can trust that your wine will always be served in its best possible condition.
Whether for a busy wine bar or a personal collection, the SC-4C-A transforms wine service into a blend of precision, elegance, and modern innovation.
Why the SC‑4C‑A Wine Dispenser Is the Ideal Choice for Wine Preservation and Serving
http://www.myaidewo.com
Zhejiang Aidewo Electronic Technology Co., LTD -
