15/07/2025 at 11:26 #3539
The surface treatment processes of the high carbon steel tube mainly include galvanizing, powder coating and blackening. Each process is suitable for different scenarios and requirements. The following is an analysis of the applicable scenarios for these three processes:
Galvanizing process
Galvanizing is a common anti-corrosion treatment method, especially suitable for environments that require good anti-corrosion performance. The galvanizing process prevents oxidation and corrosion by forming a zinc layer on the surface of steel pipes. Its main applicable scenarios include:
– Normal temperature and dry environment: Galvanized steel pipes are suitable for pipelines used under normal temperature and dry conditions, such as building drainage systems, gas pipelines, etc. Because the zinc coating is not prone to oxidation reactions in a dry environment, it can provide good protective effect.
– High-salt and humid environments: Galvanized steel pipes are to some extent suitable for high-salt and humid environments, such as ports and installation environments in subtropical countries. Zinc coating can still provide certain anti-corrosion performance in a humid environment, but long-term exposure to a high-salt environment may lead to accelerated corrosion.
– Indoor use: Galvanized steel pipes are suitable for indoor piping, such as building water supply and drainage systems, ventilation systems, etc. Due to the high brightness of the galvanized layer, it is suitable for indoor environments that have certain requirements for aesthetics.
Welded steel pipes: Galvanized steel pipes can be used for surface treatment of welded steel pipes to enhance their corrosion resistance. For example, it is widely applied in fields such as construction, electrical equipment, and automotive structural components.
However, galvanized steel pipes may experience blackening in certain special environments (such as high temperature, high humidity, and high salt), which is mainly due to the electrochemical corrosion caused by the uneven distribution of lead elements in the zinc layer. To solve this problem, passivation treatment is usually carried out after galvanization to enhance its corrosion resistance.
2. Powder coating process
Powder coating is a process that adheres plastic powder to the surface of steel pipes through electrostatic spraying, mainly used to enhance the anti-corrosion performance and aesthetic appeal of steel pipes. Its applicable scenarios include:
– High decorative requirements: Powder coating offers a variety of color options and is suitable for occasions with high appearance demands, such as the exterior walls of buildings, billboards, street lamp poles, etc. For instance, lighting poles are usually required to undergo hot-dip galvanizing anti-corrosion treatment and be powder-coated to ensure a beautiful surface and prevent blackening.
– Outdoor use: Powder-coated steel pipes are suitable for outdoor use, such as Bridges, tunnels, highway guardrails, etc. The powder coating layer can effectively prevent the erosion of corrosive substances such as rain and acid rain.
Anti-corrosion in special environments: Powder coating can offer excellent anti-corrosion performance and is suitable for steel pipes in some special environments, such as chemical plants and oil platforms. The powder coating layer can effectively isolate corrosive media and extend the service life of steel pipes.
The powder coating process is usually carried out after galvanizing to ensure the adhesion and durability of the coating. For instance, when spraying fluorocarbon paint on galvanized steel pipes, phosphating treatment is required first to enhance the roughness and adhesion of the galvanized layer. In addition, for the powder coating process, attention should also be paid to the surface treatment before painting, such as removing oil stains and rust, to ensure the uniformity and adhesion of the coating.
3. Blackening process
Blackening is a treatment process that forms a black oxide film on the surface of steel pipes through chemical oxidation reactions, mainly used to enhance the corrosion resistance of steel pipes. Its applicable scenarios include:
Fasteners and small mechanical parts: Blackening treatment is often used for fasteners, springs and other small mechanical parts to enhance their surface corrosion resistance. The blackened film can effectively prevent oxidation and corrosion, and extend the service life of parts.
– Friction parts: Blackening treatment can enhance the hardness and wear resistance of the steel pipe surface, making it suitable for parts that need to withstand friction, such as gears and shafts. Blackening film can reduce the wear between friction pairs and increase the service life of parts.
Anti-corrosion in special environments: Blackening treatment can be applied to steel pipes in some special environments, such as chemical plants and oil platforms. The blackened film can effectively isolate corrosive media and extend the service life of steel pipes.
Blackening treatment is usually carried out after shot blasting on the surface of steel pipes to make the crystalline particles of the blackening film fine, uniform and dense, thereby enhancing its corrosion resistance. In addition, blackening treatment can also be combined with other surface treatment processes, such as galvanizing and powder coating, to enhance the comprehensive performance of steel pipes.
Summary
The galvanizing process is suitable for environments such as normal temperature dryness, high salt and humidity, and indoor use, but attention should be paid to the issue of blackening.
The powder coating process is suitable for occasions that require high decorative quality and outdoor use, and is usually combined with the galvanizing process.
The blackening process is suitable for small mechanical parts such as fasteners and friction parts, as well as anti-corrosion requirements in special environments.
According to the specific application scenarios and performance requirements, the appropriate surface treatment process can be selected to ensure the anti-corrosion performance and service life of the steel pipe.
http://www.torichsteel.com
TORICH -
