17/08/2026 at 10:10 #5826
When a road authority installs an electronic speed warning sign, the main concern is not simply whether the sign can display a speed limit. It also needs to remain visible and functional when traffic conditions change or when the weather is less than ideal.
This is one reason light up speed signs have become increasingly useful on roads where speeding is a recurring safety concern. By combining illuminated displays with real-time speed detection, these signs can give drivers a more immediate warning than a conventional static sign.
Power availability is another practical issue. Solar-only equipment can be affected by several days of cloudy weather, while a mains-powered system may be less flexible in locations where grid access is difficult. A dual-power configuration addresses this limitation by combining solar charging with mains electricity.
FAMA Traffic provides this type of solution through Yangzhou FAMA Intelligent Equipment Co., Ltd., also known as FAMA – The Leading Enterprise In China's Traffic Signal Lights Industry. Established in 2005, the company works in intelligent transportation, traffic safety, smart signal control, and 5G multifunctional smart pole applications.
Why Road Authorities Use Illuminated Speed Warning Systems
Speeding is not equally dangerous on every section of a road. Certain locations have a higher probability of accidents because of road geometry, traffic volume, merging movements, or limited driver visibility.
Typical examples include:
Highway ramps
Urban arterial roads
Accident-prone intersections
National and provincial roads
School zones
Road sections with repeated speeding violations
A static speed limit sign tells drivers what the permitted speed is, but it does not actively indicate whether a particular vehicle is exceeding that limit.
An illuminated speed warning sign can provide an additional layer of information. When the system detects a vehicle traveling above the configured limit, the display can provide a visual warning that is easier for the driver to notice.
For traffic management departments, this creates a relatively direct way to improve driver awareness without relying entirely on enforcement measures.
Why Dual Power Is Useful in Real Road Conditions
Solar power is an attractive option for roadside equipment because it can reduce dependence on grid electricity and simplify installation in locations without convenient power access.
The limitation is obvious: solar generation depends on available sunlight.
During the night, the system relies on stored energy. Several consecutive days of rain, heavy cloud cover, or other low-light conditions can also reduce the amount of energy available for charging.
This is where the dual-power configuration used by FAMA becomes valuable.
The system can use solar energy as a primary power source while maintaining mains electricity as a backup. When solar generation is insufficient, the mains supply can help keep the equipment operating.
For traffic authorities, this redundancy is particularly useful at locations where a non-functioning warning sign could reduce the effectiveness of the entire safety system.
The system also incorporates battery protection functions. Sealed maintenance-free gel batteries can be used together with circuits designed to protect against overcharging and excessive discharge.
This combination helps reduce maintenance requirements while supporting stable operation over extended outdoor service periods.
Radar Detection Makes the Warning More Responsive
Another important difference between a conventional sign and an intelligent speed warning system is the ability to detect vehicle speed.
FAMA's dual-power light up speed signs can integrate millimeter-wave radar for real-time vehicle speed measurement.
Instead of displaying the same message continuously, the system can respond according to the detected vehicle speed.
For example, the sign can provide:
Current vehicle speed information
Speed-limit indication
Flashing warnings for overspeeding
Dual-color visual alerts
Additional text messages where required
This makes the warning more directly related to what the driver is doing at that moment.
The system is particularly useful on roads where drivers may unintentionally exceed the limit because of downhill sections, highway merging, wide road layouts, or changing traffic conditions.
Providing the driver's actual speed alongside the applicable limit can make the difference easier to recognize immediately.
Display Design Is Important for Driver Recognition
Radar accuracy is only one part of the system. The information also needs to be visible quickly enough for the driver to understand it.
FAMA's signage combines several visual elements to create a layered warning system. Speed-limit information can be displayed together with dynamic speed feedback and warning messages.
This approach avoids forcing the driver to interpret complicated information while moving.
The optical system also needs to work during different lighting conditions. Daytime sunlight, nighttime darkness, rain, fog, and other visibility conditions can all affect how easily an electronic traffic sign can be recognized.
High-luminosity LED components help maintain clear visual output, allowing the warning information to remain noticeable across a wider range of road conditions.
For safety applications, this visibility is just as important as the radar detection itself.
Outdoor Housing Needs to Withstand the Environment
Traffic signs are installed outdoors for years rather than days. Their enclosure therefore has to deal with rain, dust, sunlight, temperature changes, and mechanical exposure.
FAMA uses high-strength polycarbonate or die-cast aluminum housing options for its dual-power light up speed signs.
Depending on the configuration, these materials provide protection against:
Water exposure
Dust
Outdoor impact
Long-term sunlight
Flame-related risks
General environmental wear
A durable housing can also reduce the frequency of maintenance caused by enclosure damage or environmental deterioration.
For municipalities and road operators, this matters because roadside equipment is often installed in locations that are difficult or costly for service personnel to access.
A reliable enclosure therefore contributes not only to equipment life but also to the overall operating cost of the traffic management system.
Where Dual-Power Speed Signs Make the Most Sense
Not every road requires an intelligent illuminated speed sign.
The strongest use cases are generally areas where speed behavior has a direct relationship with accident risk or traffic safety.
For example, an accident-prone intersection may benefit from a system that gives drivers a warning immediately before they enter a conflict area.
On highway ramps, drivers may accelerate or fail to adjust their speed appropriately as road conditions change.
Urban arterial roads can also benefit from dynamic speed feedback where traffic volumes, pedestrian activity, and intersection movements create more complex driving conditions.
School zones and other areas with vulnerable road users are another practical application because making speed-limit information more noticeable can improve driver awareness.
The correct installation location should ultimately be determined by traffic data, road geometry, accident history, and local operating requirements.
Combining Solar, Radar, and Intelligent Displays
The real value of FAMA's system does not come from any single component.
Solar power addresses energy supply.
Mains power provides redundancy.
Battery management supports stored-energy reliability.
Radar provides real-time vehicle speed information.
LED displays communicate the warning.
The weather-resistant enclosure protects the entire system.
These elements work together to create a traffic warning device that is more suitable for long-term roadside deployment than a simple illuminated sign with a single power source.
For traffic engineers, this system-level approach can be more useful than evaluating each component separately.
FAMA Traffic and Intelligent Transportation Applications
Yangzhou FAMA Intelligent Equipment Co., Ltd., operating as FAMA Traffic, has been involved in intelligent transportation solutions since 2005.
The company provides products and services covering smart traffic signal control, traffic safety systems, and 5G multifunctional smart poles. Its work also includes system optimization, operation and maintenance, and customized solutions for complex intersections and high-risk road sections.
The company's experience is relevant when traffic authorities need more than an individual roadside device. Different locations may require different combinations of warning equipment, power configurations, communication systems, and traffic-control technologies.
For customers evaluating light up speed signs, FAMA can provide solutions based on factors such as road environment, available power infrastructure, traffic conditions, and deployment requirements.
Its project portfolio provides examples of the company's involvement in traffic safety and intelligent transportation applications.
What Should Be Considered Before Installing a Light Up Speed Sign?
Before selecting a system, traffic departments should look beyond the displayed speed value.
Several practical questions are worth considering:
Is grid electricity available?
If not, solar power may be necessary. If the location experiences long periods of low sunlight, a dual-power system can provide additional reliability.How often does speeding occur?
Radar-based dynamic warning is particularly useful where speeding is a documented problem.What are the local weather conditions?
Rain, snow, dust, high temperatures, and prolonged sunlight exposure should all be considered when selecting the enclosure and protection level.How visible does the warning need to be?
Road width, traffic speed, ambient lighting, and viewing distance affect the required display configuration.How accessible is the installation location?
Locations that are difficult to reach may benefit from maintenance-free batteries and durable outdoor construction.Does the sign need to integrate with other traffic systems?
For larger intelligent transportation projects, compatibility with existing traffic management infrastructure may be an important selection criterion.These considerations help ensure that the installed system matches the actual road environment rather than simply meeting a basic product specification.
FAQ
How does a dual-power light up speed sign work?
The system combines solar energy and mains electricity. Solar power can be used during normal operation, while mains power provides an additional energy source when solar generation is insufficient. Battery storage helps maintain operation when external power is unavailable.
Why use radar with an illuminated speed sign?
Radar allows the system to determine the approaching vehicle's speed. The display can then provide dynamic feedback or an overspeed warning instead of showing only a fixed speed-limit message.
Where are these signs commonly installed?
Typical applications include accident-prone intersections, highway ramps, urban arterial roads, school zones, and other locations where speeding presents a significant safety concern.
Can the signs operate during extended cloudy weather?
The dual-power design provides an additional power source when solar generation is reduced. Battery storage and mains electricity help maintain operation during periods when sunlight is insufficient.
What materials are used for outdoor durability?
FAMA's systems can use high-strength polycarbonate or die-cast aluminum housings. These materials are selected to provide protection against outdoor environmental exposure, including dust, water, sunlight, and general mechanical conditions.
Final Thoughts
A speed warning sign is only useful when drivers can see it, understand it, and receive the warning when they need it.
That is why modern light up speed signs increasingly combine dynamic radar detection, high-visibility LED displays, battery management, and reliable power systems rather than relying on illumination alone.
FAMA Traffic's dual-power approach adds another level of operational redundancy by combining solar generation with mains electricity. For roads exposed to variable weather, heavy traffic, or recurring overspeed problems, this configuration can provide a more dependable foundation for intelligent speed-warning applications.
For municipalities and traffic engineers, the most appropriate solution should ultimately be based on road conditions, traffic behavior, environmental exposure, power availability, and maintenance requirements.
https://www.fama-tech.com/
Yangzhou FAMA Intelligent Equipment Co.,Ltd -
